That's the thing. It's intermittent and even just the weight of the RCA lead can 'fix' it. I bet the tech tested it and it worked perfectly.
Funny, I put off doing my own TAN 77es for about a year or two because I "knew" it was the speaker or input relay and I could be bothered pulling the unit down. I also "knew" it couldn't be the RCA input jacks because I tried both fixed and variable and both lefts behaved the same. I just got out another TAN-77es and put the unit on the back burner until I had space on the bench for the monster.
But I was wrong. Two left centre pin RCA bad solder joints. Sony didn't use anywhere near enough solder (that's original factory in the above pic) on the lefts for some reason and dis-similar metal corrosion on the pins did the rest. In the end, all it took was 10 minutes to fix as the input board is easy to remove and work on without dismantling anything.
