howaboutthis
TheRed1,
Thanks for the link.
It appears, from the diagram that one of you, (sorry, I forget who), was kind enough to post, that all I need to do is add power at pin #2. And, (this is where my inexperience has me confused), pin #11 seems to ground through the tube heaters on the tuner.
The pdf I downloaded is entitled: "Electra-VII-Fisher-Model-E-49.pdf". I don't know how to attach it (or where I found it.), but I am thinking it may have been you who posted it. Let me know if you have no clue what pin 2 and 11 are and I will find the link or email it to you.
I read, in a different thread, that you should use a 300-330k resistor there. I assume just tied to chassis ground?
Any help would be appreciated here, as I am new to reading valve schematics and you are the only source of actual info I have found, on this amp. My goal is to make some noise and no smoke, so....
Also, does anybody know if these amps have enough gain to be driven by a CD player and a passive volume "pre-amp"?
Thanks, Eric
Thanks, Eric
