I've been reading this thread and other similar threads on AK and other forums. I was wondering how, or would, updating change the specs. The specs say the frequency response is 30-15,000. Would updating the components increase the frequency response? I've attached a list of the specs I lifted from another forum.
Stereo Pre-Amplifier
(420-2101A) Specifications Faxback Doc. # 40137
Sensitivity (for 200 mV output at 1 kHz, 50 K Ohms)
Phono............................................................... 2.5 mV
Output Level, 50 K Ohms Phono, 3 mV Input........................... 240 mV
Maximum Output Level at 1 kHz........................................ 6.0 V
Input Overload Level (for 1% THD) Phono............................. 100 mV
Signal to Noise Ratio Phono, 3 mV input.............................. 55 dB
Frequency Response.................................. +/3 dB: 30 - 15,000 Hz
RIAA Equaliztion................................................... +/-2 dB
THD at 200 mV Output.................................................. 0.5%
Stereo Separation at 1 kHz........................................... 50 dB
Impedance
Inputs............................................................ 55 KOhms
Outputs........................................................... 50 KOhms
Power Requirements..................... 120 volts AC, 60 Hz, 1.5 Watts Max.
Size.......................................... 50 (H) x 90 (W) x 120 (D) mm
(km-06/20/1997)
