Chapter 9: Coupling Cap Replacement Report
Dear reader, yours truly suggested that it could be some time before new coupling caps could be installed and could ripen in circuit. Some idle time last evening afforded your technician and scribe the opportunity to put some Sprague 716P orange drop caps in place of the Fisher Doc choices.
You may recall that the author felt that the coupling caps in Fisher 400 SN27949P were not up to the standard that the author uses in evaluating components, that the bass was non-authoritive and the treble was present but smeared, and not crisp.
Yours truly believes that he may be in the wrong business. The right business to be in might be boutique coupling caps for audio tweakers. According to this lengthy, instructive and useful dissertation on the subject, which the author rates highly along with Joe's tube lore,
http://www.enjoythemusic.com/diy/0708/capacitor1.htm, Sprague orange drops were not even worth a mention. At $2 to $3 a pop they couldn't be any good . . . could they? Do they have a reputation based on old information and the boutiquers have superceded them by an impossible to pass margin?
Well, they're not pretty, they don't have fancy leads, they're cumbersome to install, and, within 24 hours of being installed in 27949P, they sound lovely! This amp sounds like magic now. That being said, there are better caps, but your equipment better be very good or you won't ever notice the difference except in the lack of heft retained in your wallet.
Yours truly believes that his boutique caps will stay on the top shelf for premium pieces along with his cognac, champagne, the best tequila, the finest gin, and the most select port. For everyday consumption this time of year, dear friends, a heavy porter with a caramel snap, authoritive bass, PRAT, well contained treble in a hint of orange drop will do.
The author installed .047uf 400 V caps in two positions in the line stage, and also in two positions in the phono stage. Also, yours truly installed .1uf 400V in two positions going to the output tubes from the phase inverters, and installed .1uf 600V in two positions going to the output tubes from the phase inverters.
These capacitors are considerably larger than the ones they replaced. There is not a correlation between size and quality per se, but size is a consideration when using caps in tight spots. For example, the .1uf Sprague Orange Drops are too large to be used in a Fisher integrated amp like the KX-200. There's not enough room under the chassis and the leads are too inflexible. See the thumbnails for further information.
While disassembled, yours truly installed some Pomona banana receptacles with retaining washers in place of the output screws. Since these are 8/32, yours truly removed the capture screws, drilled out the holes and tapped them with an 8/32 tap. The retaining washer between receptacle and the Fisher is key because the thread ends before the banana receptales can be turned down tightly.
After testing all inputs and running our charge all night on the workbench connected to an antenna and speakers, it was moved back into the office system today.
Listening to Plant/Krauss's Raising Sand was a pleasure. For the uninitiated, this 180G vinyl release from 2008 presents an odd sonic landscape. The kick drum is a tubby huge drum from a 1930s trap drum set, probably 44 inches or larger in diameter, and vintage instruments are used through and through. Without careful listening, one might think this a sloppy thrown together recording. In truth it is a carefully crafted vintage sonic landscape achieved with the highest caliber of musicians and equipment.
On the Fisher, it was just lovely. By the way, the CD is too heavily compressed to show the magic of this dynamic two disk 180g vinyl set. It just sounds boomy and fat. Find the vinyl version. If you can't find it and it's too expensive to buy from your usual online mill, PM me and I'll find you one and ship it. Newbury comics carries it locally and it's $18.99.
Supporting equipment:
Thorens TD320 with AT440ML cartridge. Heavily tweaked.
Audio research interconnects.
Fisher 400 SN27949P
Nordost Blue Heaven speaker wire
Spendor SP1/5 minimonitors (a 6" and a Vifa tweeter) on 36" stands.
Hsu STF-1 subwoofer run from the RCA center channel out
Cambridge Audio Azur 840C upsampling CD player
My copy of KD Lang's Ingenue on CD was rich and ripe. Honestly, dear reader, yours truly does not want to leave his desk for dinner, but wishes to keep his head, so this chapter will end.
