Good to hear this hyraz, I was going to pull the trigger on the Yes box set based on the Tull remixes.I bought the box set and hoped it would have been better but honestly couldn't bear to listen to more than a few cuts. I don't know what he was shooting for, it was all wrong.
This box is based on his mixes previously available on blu-ray and DVD-A, maybe that's the problem. Perhaps he should have mixed it for vinyl.
Other remixes by him are phenomenal, this one was really a disappointment.
I did read "bad" reviews on the net, so I was very cautious. I bought the box set discounted from the Bay and glad I did (not a huge loss). I think the guy ran the music thru a poorly set up BBE sonic maximizer. Very close to the worst vinyl I have ever heard. We may have to have a burning party later this week. I think I will enjoy watching the box set go up in filthy smoke and flame. John, look north for the next few evenings and see if you can see the smoke and flames.
What I don't understand is how the producers of this material could possibly let this stuff pass as anywhere near quality recordings. I have stuff from the 60s that sound 10...no 100 times better.
They are not just remasters but remixes.
If you wanted the original mixes you made a mistake by purchasing the box.
I ended up getting the HDTracks version since these mixes are all done in the digital domain anyway. I think they're interesting as an alternate take on the albums for a fan. Wilson likes to de-construct them and put more space between the instruments and different sonic elements - that's his style. Are they substitutes for the original mixes? Absolutely not.
Don't breathe any of those vinyl fumes mate, they can't be good for you. Maybe make some of these instead?
Yes, I knew they were remixes, I guess I should have said that rather then remastered in my title.
Anyway, all the life of these 5 LPs has been sucked out. No real "twinkle", very mono-ish, also recorded at a very low volume, so you need to crank your volume up, it shows low compared to the rest of my LPs on my VU meters.There isn't any space between the instruments, its all crammed together. Its a disaster.
I can't speak to the LP versions, only the hi-rez download.
Not sure what version you have, but it looks like the U.S. and European pressings might be different in terms of who cut the lacquers. It appears that some or all of the U.S. box was cut by Chris Bellman (check your deadwax). He normally does a good job, but the trouble when cutting from a digital source is how it is prepped before it reaching the cutter. If it's too loud to begin with then you might have to cut it at a lower volume to avoid problems. This is a common problem with newer vinyl that's digitally sourced. Some LPs are intentionally cut at lower volume with little to no compression so you have to turn them up so they "bloom". A lot of current MOFI LPs are like that.
Anyway, the digital version of the remixes is available on Tidal if you want to listen it and compare with your LPs.
Likewise, if you want to sell your box I'm sure you won't have too much trouble doing that.
All vinyl cut nowdays is brought into the digital domain so that the cutting lathe computer can adjust groove spacings.
I don't need to download anything to compare it to as I have other LPs here to compare it to.
Computer controlled groove spacing and analog preview head + analog signal are not mutually exclusive. Are most LPs nowadays cut from a digital signal? Yes, but certainly not all. There are mastering studios that can cut all analog still and do it all the time.
I think you missed my point. The point was, listen to the digital versions of the remixes and figure out if the problem is the cutting or if you just don't like the remixes. If you don't want to do that and just get pissed off that the remixes aren't the same as your original mixes on vinyl, have at it.
