Rob DeFries
Yesterday I received my copy of the Guanzo version 2.2
I've read a lot anout it already, but I haven't seen many solutions to many answers.
I did find a schematic, but than again a schematic without power- and heater supply.
Atleast now I know where to look if things go wrong.
Here is the somewhat clumsy but readable schematic.
There are some thing wrong with the board, so I rather check everything first, before I hook up a transformer which produces 238 Volts at idle.
The filament is the wrong way around. Under the 2200uF/16V cap are 3 small holes. These holes connect to ground on the bottom. But that now has the + of the filament on it.
The correct way to solve this is to put the cap in the other way, but also the rectifier needs to be reversed. For both the cap and rectifier bridge counts: the + has to go into the - hole.
