This hobby too expensive???
Not at all...
I've had the most fun when I had the least money.
As has been said, Vintage and DIY are really where it becomes a hobby rather than a purchase.
Having said that, if you drop yer wallet I'm gettin' a set of mono blocks and pair of B&W Nautilus... :D
Everybody is entitled to their opinion. I think 7k is the point where you start heading for the last little bit in my eyes. I listened to tons of speakers and gear when we had decent audio shops around here. Now it is all home theater crap. I am one of those people who unfortunately cannot afford super high end stuff. If I could I would definitely assemble a system to see what that kind of money gets you. Maybe someday I'll win the lottery or my financial situation will improve alot. Until then I'll enjoy my systems and listen to a ton of music. :music:
You're more likely to put together a $7k system that sounds like a $1k system than a $1k that sounds like a $7k. This, again, is why it's important to know your priorities and know what is available.
But I take your meaning (I think). I'd wager that everyone here is interested in putting together a system that performs well above what they paid for it. That's the culture of AK. My $5k system that would retail for around $12k is the same in a relative sense as someone whose $500 system performs like a $1,200 one. The challenge is staying ahead of the value curve and not end up with those figures being inverted.
The challenge is staying ahead of the value curve and not end up with those figures being inverted. Well said, that is the crux of the matter. I've done pretty well at this myself, but see others here who've done even better. Geography can play a larger role than some folks appreciate simply due to the choices for those who live in more densely-populated areas. I find myself often envious of people who live in the Northeast, Chicago, or LA, for instance, when I see the used-market competition on CL, BT, the bay and other such sites where local pick-up is a great advantage.
OP:
You have received a lot of good advice on equipment and sources and having patience. Now to the "little" stuff, interconnects, speaker cables and power cords and "magic tweaks".
Much of the sales hype around these items is just that, hype. If expensive ones improve things at all it is really only marginal. To keep things reasonable use this approch:
Power Cords: All the power cord need to do is connect from the unit to the power plug. It needs to stay in the unit (if it is an IEC connection) and in the wall. It needs to not get warm when the unit is operating. Once it does all that you are done. Cheapest possible cord that does that. If there is one with the unit use that and don't look back.
Speaker cables use lamp cord from your local home depot or hardware store. When you look at the cord you will notice that one side of the insulation has ribbs on it and one side doesen't. That allows you to keep the speakers in phase.
Interconnects. Use whatever comes with the units. If you need to buy some, least expensive you can get.
Know that solid state equipment can be had for a lot less then comprably powered tube equipment. Also, as a class of equipment, solid state equipment tends to need less maintenance and fewer repairs then tubes. Having said that however, when a solid state device fails there is often a "cascade failure" when the failure of one part can cause another or more then one other part to also fail, resulting in more troubleshooting time and therefore more cost to repair. Overall however I believe it cheaper to go solid state.
I hope this helps.
Shelly_D
I'd suggest he go for it. But slowly. maybe start with a $200 system to learn what you like. This is a hobby of compromises and you need to know your own priorities so you don't waste money on the wrong attributes.
Thats exactly how I did it. Resist the impulse, and try to audition before you commit. :thmbsp:
OP:
I hope this helps.
Shelly_D
This is a joke and I'm supposed to laugh right? You're saying I should hook up my $4000 pair of speakers to my $5000 amp using lamp chord? Sounds like a great idea and tweak to me!
Most of my favorite music was recorded like this:
I am asking in all serious, not trying to be snarky. Will a 7k system squeeze anymore musical information out of that single mic and a 45 year old master tape? Shouldn't the type of music you listen to be a factor in choosing equipment?
It can be, some gear will enhance the sound of some things too. Not all of us are after pure accuracy, we just want something fun to listen to. The only person that will know if higher dollar system is worth it is you. Have you listened to that on any $7k systems yet? ;)
Well if you think that copper costing $50/foot sounds better then copper costing $0.25 per foot, go right ahead and spend your money. As an engineer with over 27 years experience in two different Bell operating companies I know that there isn't.
Shelly_D
This is almost what I did. B&W 802D to Bryston 4BSST. Not exactly lamp cord, but $60 for 50' 12ga cable. No complains on sound.
The Hippy Boys know how to do it! The eventually became Bob Marley's backing band during his Island years. I must admit I've never heard a 7k system. That's why I was asking. :music:
Shelly_D
You should write to TAS and Stereophile and let them know this remarkable fact! You'd be saving their readers a ton of money! Have you actually listened to well designed speakers hooked up with quality speaker cables?
Shelly_D
I recall that we had an AT&T communications specialist here a bit ago that disagreed with you. But none of us want to see an engineer fight, because only the viewing/giggling public wins that one.
I do, however, agree that at the lower end of budgets, wire is not the place to sink the budget. There are bigger fish to fry at that point.
BTW, I have known a host of engineers who can't seem to tell the difference between "it works" and "this works better than that to your personal preference, even though both work".
It is the same with all hobbies!:yes:
I found just the other day that a $100 deal for some RC cars on cl with quickly cost more than 1k once you add this motor and that battery. Then there is shocks tires controllers this and that............
It just keeps going. But did my sons and I have fun?
ABSOLUTELY!!:banana:
In the end it is all about you. If it bothers you to spend that kind of money on audio gear then get some ear buds and a player/phone and be on your way!
How we enjoy our hobbies is "In the Eye of the Beholder"
JMO Enjoy!:music:
I wouldn't take anything a engineer from AT&T has to say as gospel,
I worked for at&t, lying to people that they are getting fiber optic quality through their telephone lines.
I also installed fiber optic, i know there is no way you are getting fiber quality through a copper phone line.
Anyway,
Is this hobby to expensive?
That would depend on your vision and wallet.
My wallet isn't as big as my eyes, but i can also live very happily with in my budget.
I am saving now for some speakers, im tired of buying used so i am saving for new.
My other hobby was RC helicopters, that was twice as expensive as this audio hobby.
I don't trash my stereo every other week, so i'm not spending $100 on every crash anymore LoL.
After 4 years, 9 heli's and almost $10,000 later, i had to stop. just way to expensive.
http://www.youtube.com/watch?v=eonBD1sMD3U&list=UUew-iPwvgTibSkNd-Ei2E_w&index=2
Well, I've heard systems costing many times $7k, and yet there are quite a large number of folks on this site who've had a wider range of experience than I with exposure to high-end toys. As far as sheer dollar amount in a basic, two-channel set-up I top out at something just under a hundred grand (speakers were fifty grand), though it wasn't extremely impressive; the speakers were poorly placed in a room which simply failed to do them justice. The best SQ I ever heard was more like half that, and you don't get that same experience for a fraction of the dough, IME.
Luckily for me, even though I can hear, appreciate and enjoy the added benefits of such well-sorted and placed megadollar (to me) components, I don't require that level of playback to enjoy music. Some people do - or at least something near it - once they've experienced it.
I don't think anybody here should take anything anybody says as gospel, including anything I say. I think people should form their own opinions with their own ears. Beyond that, they can listen to varying opinions and make up their mind on who to listen to based on what jives with what they themselves hear.
Contrary to what some believe, having really nice/expensive gear is all about getting the system out of the way of the music. The better my system gets, the better everything sounds. I don't know how it could be otherwise.
FWIW, a lot of the music I listen to was recorded all around the advent of stereo; 1956 to '60 or-so. And it just keeps sounding better and better with every upgrade. My 78's have also come to life with a higher fidelity set up.
I think this points back to knowing what your priorities are. If you listen to stadium rock, you needn't spend money on wringing out the last fine details of instrument timbre and could go with some pretty blunt-instrument, brute-force equipment with good dynamics and lts of power to push the SPL up to insane levels!
If you listen mostly to string quartets you wouldn't care too much about the extreme lower octaves but would benefit from assembling something that's capable or retrieving fine details.
etc,etc.
that's why it's very important to listen to every piece before you commit the money if at all possible.
OTOH, if all you do is have music on while you're doing other things, then spending thousands would also be a waste. How good a TV would you need if it was just going to be playing in the garage while you worked on your car?
People here often act as though there is one goal; one set of needs that can be universally addressed. There certainly isn't. If I just wanted background music, I'd be quite happy spending a lot less.
I hope this helps.
Shelly_D
I wondered that too and was slightly disappointed to see he was serious. That's some of the worst advice anyone could give or get if you ask me. Even the most earnest cable deniers will tell you to throw out the cheap/free patch cords and buy something well-built and shielded.
:sigh:
A good percentage of members probably don't even do any real auditioning of the equipment they purchase. How many around here even walk into a stereo store these days.....that's even if there's one in their area? And what kind of after purchase support do you get from Ebay, CL and thrift store buys. None....you're on your own!
It's not like you can borrow the component(s) to see how it sounds in your own system. Being able to bring it back and exchange it if you're not satisfied with how it sounds in your own system. Is a very nice option when dealing with a dedicated stereo store!
