shelly_d
Not An Audiophool
Speaker cables do not need shielding because of the high level signal they carry. Low level signals, such as from a source to amp, or much more important a turntable to Phono preamp very defiantly need to be shielded. If you ever cut apart the cheapest interconnect you will see that it is shielded. These may not meet some standard of performance or quality level you have for your system but this is advice for someone that very clearly has budget concerns. Wire and coax cable are not the places to spend money on when putting together a budget system.
We can debate just how audible high priced cables and wire is in another thread, but I stand by my advice to the OP regarding his entry into this hobby.
Also, when someone posts back to me "have you ever tried it" and if not you really don't know, I respond this way. When you jump off a cliff, you will fall, it is a law of physics that on the surface of large body such as the Earth, gravity will pull objects toward the center of the earth. There are other, equally immutable laws of physics at work in the audio systems. If you know what is at play, you can predict the effect on the output. That is how science and physics work. Should you believe otherwise, I cannot change your mind and do not wish to. I post here for the benefit of the OP who is also free to make up his mind.
Shelly_D
Shelly_D
