Thorens TD-126 MkII thoughts/advice
Let us know. You may be a novice, but you're analyzing everything correctly, and you don't seem frightened of the challenge, just cautious, as you should be.
Went back in an removed that white box and it seems that there is some slack in the colored tonearm cables themselves, but its that one nude color cable going into the box that has no slack. Maybe there's a work around, but I can't figure it out. This is a close up of how my cartridge is sitting on an LP during play. Anyone know someone in the NY area that works on turntables, preferably Thorens?
So I'm wondering if I unscrew the wire where indicated below, add a few inches of wire to the end and and screw the other other end back in to give me more slack. I think its the shortness of this wire going into the white box that is giving me trouble. What do you think?
Your arrow points to 2 wires, so I'm not sure which you mean.
There's a chassis-ground-wire (the thin one): it grounds the two parts of the suspended chassis. It does not travel Up or Down when you raise or lower the arm, so it can't be pulled too tight. It's not the problem.
But it also points to a screw which has another wire (thicker) that goes into hiding under the white box. That probably connects to the tonearm-ground-wire.
If it were me, I'd look under the white box — that's where the 4 signal-wires exit the arm-base (and a fifth arm-ground wire) and connect to the thicker black output cable.
I suspect that's where the problem is. It could be very simple you'll see: maybe a wire is snarled on something and can't move freely. Just remove the box, and snap another photo. Nothing will be damaged.
Thanks, bimasta. Here is a photo with the box off. Seems that there is enough slack in the 4 signal wires to give me the 2mm more I need to raise the tonearm. Nothing seems snagged.
So I carefully stood the TT on its side so I could loosen the hex nuts and tried to raise and lower the arm while watching what was going on underneath. The white circular drum into which the tonearm wires go tuns nicely and the wire did not reach any stretching point. But at some point when I tried to raise the arm, the drum seems to be scraping against something and not turning, as if its reached its maximum height and is not designed to go any further.
Looks like this is the way the TT is built. Not a big deal and am very happy with how its performing, though. I want to thank you again for all your help and guidance. Its been very instructive!
As it looks normal to you, and within the limitations of a static photo, I can only guess at this point.
There may be a 'stop' to set a 'maximum height' for the arm, in connection with the auto-liftoff — too high and the lift won't reach it. If so, it would be intentional. (I know the cue-bar is height-adjustable, but within limits).
Yet you describe a "scraping sound". That suggests something out of adjustment, two parts scraping that shouldn't be — Thorens didn't design scraping sounds into their TTs. I'd be tempted to examine further to locate what's scraping — but I've played inside a few TD125s and one 126, and probably feel more comfortable doing it. At least you've learned a lot more about your superb TT through this process. For example, you'll know how to adjust the suspension, should it be needed.
It's good you're happy with it, but that arm-angle just doesn't look right. Nor intentional. I couldn't let it rest, but that's just me and my 'perfectionism.' For instance, I'd take out that screw with the blue paint (last pic) to see what lurks below that white disk. Of course, I'm not trying to tempt you... farthest thought from my mind...
I hear you. I'm not likely done (and getting increasingly comfortable taking this thing apart and putting back together again. Seems to me that the fin that sticks off the barrel (at around the 6 o'clock mark) limits how far up into the shaft the barrel can go. Not sure if its a design issue or a defect on my table. I do see others complaining about being able to get a level VTA with the TP-62 wand and modern cartridges in part because the way the headshell on the TP-62 is designed. They say one fix is to move to a TP-63. But not giving up yet!
Yeah, my eye zoomed in on that 'fin' right away: looks like a designed-stop — but it wouldn't "scrape", just stop.
I never used the Thorens arms, no matter which model. I always replaced them with what I thought "better", so I can't really advise re the arm in isolation. Changing arms on my 126 meant losing the auto-lift, which I'd rather have kept — I thought I could have made it work, but never had the time to try.
As for the headshell, my 126 had a sliding 'block' — not the horrid old h'shells Thorens used to use. But the old h'shells at least raised the cartridge quite a bit above the level of the armtube (which the block didn't) and that could very well account for your height issue.
Just to close the loop here, I ended up getting a couple of TP-63 wands - they were delivered from Germany just this weekend and that's done the trick. I have the VTA right were it needs to be for the AT. Also installed the AT VM Mono cartridge on the 2nd arm. Got the cork/rubber mat and center weight as suggested and had a great time with this TT this week, listening to hours of vinyl. Thanks for all the thoughtful advice!
Welcome to the posting side of AK..
There are a number of cartridges sold on Barter Town, the buy sell trade subscription only forum. Only fee for transactions from this venue. $25 per year is cheap, kinda but you might get caught buying too much.
The Ortofon Black>>Bronze or the new Audio Technica VM series, 700-600-500 allowing any stylus of the series to be used and there is a 78 stylus in the group. Get the good VM and the 78 stylus and swap as needed. I don't know prices of these but glad to see you wanting to get something appropriate instead of choking the signal as it leaves the record with a cartridge not up to the ability of the table. Budgets are real I understand but good table can get a lot out of better cartridges.
The herbies mat worked best on my TD-160 Super but I didn't hear much difference on the 125 listening to 5-6 different mats. My 125 came with a herbies so I'm happy
This arm is low mass. I'd put an Ortofon OM or Super OM series on it, a Super OM 20 and get the Ortofon 78 RPM stylus for that. Better match for the tonearm than a 2M is. And the Audio-Technica you have, is superb for mono duty.
