Shindo-Joe
Hello from up north!
I finally put my hand on a turntable to experience the true analog sound. 200$ for an original TD-160 in great condition seems too hard to pass on. So without any knowledge I’m jumping in to realize that theres a isht tons of stuff that I need to learn to make more educated choices...
The table is going to be connected to a Shindo Monbrison last Ken model circa 2012 phono stage. I see people getting step up transformers etc. I’m not certain what are the advantages and if its required depending on cartridge and stylus that is chosen.
The matching part between the system and the cartridge eludes me completely, so any light shed will help me greatly. Around a $500 -1K budget what should I look at if I use the original TP-16 and/or should I go and change the arm completely?
Thank you in advance for your guidance!
Jonathan
Jonathan
I have some mid 1940, 50s first press that are patiently waiting. Some are mono I think..Maybe with noise issue, hopefully pleasant noises mind you!
I get to use the Weller as a bonus. That’s all it takes for a great adventure!
