tnsilver
Stereo Puppy
Thanks for that picture. Your speed change assembly looks fine. I've opened up another TD-160 (Mk-II) with a similar assembly to study it.
Mine runs fine so I had to simulate a similar malfunction.
Your issue seems to be with the "S" shaped guiding wire spring:
It is known to happen that this guide spring fails to align the two dents in the "S" part with the vinyl sleeve on that lever and it keeps the speed change assembly from locking to the 33RPM position.
When this happens, before you force the guide lever down to it's final downward 33RPM position, the assembly looks like this:
BAD:
When in fact, it should look like this:
GOOD:
FIX:
To fix this there are two approaches you can take:
BAD:
GOOD:
FIX:
- The first involves trying to position the spring back in it's designed location, just in case it escaped, and attempting to bend it a little back or a little forward, until it clears the final gap and the vinyl sleeve is resting inside one of the "S" dents. This requires some playing around with the spring and speed control knob simultaneously and in general - not hard to achieve. It can get tricky b/c that wire spring is tough and you do not want to deform it by bending it too much in either direction. Dave, from Vinyl Nirvana had addressed this exact fix in one of his great TD-16X maintenance videos on the tube.
- The second is a workaround (a 'cheat' if you will) which makes the speed change assembly connection rod perform that little extra push on the belt guide lever to force it to complete the full stroke to 33RPM. It can be done by installing a thick enough rubber washer/spacer at the end of the nylon stopper. My trick is doing it with 2 or 3 winding of solder - which provides better control over the thickness of the solder spacer:
- This is what it looks like at neutral:
- ...and this is what it looks like at 33RPM:
Once you figure out the exact gap that's missing for the lever to pull back for 33RPM you can fill it in with solder winding. I guess two or three would do it. Once fixed, you could also use a drop of contact cement to keep that solder loop in place and avoid it getting loose and unnecessary rattling.
For a beginner, I'd recommend the second approach which involves less potentially irreversible tweaks.
