the TP-50 headshell, which is actually the only Thorens headshell with adjustable VTA.
How does that work, spacer shims like the TP-60 or does it use some other mechanism?
I am using 2mm r/c car axles to replace the spindle. I measure the Thorens one at 1.9mm with my vernier, which, granted is not immune from error, so I think they should fit when I have a chance to get to the hobby store.
No, there are set screws at the back which allow you to move the entire headshell top which the cartridge is mounted to forwards, backwards, up and down. It's a clever, if fiddly mecanism.
The roof of the headshell is hinged on a couple of screws in slots. A small pilot screw serves as a guide as it slides back and forth in the slots. Originally designed for a sliding lateral movement to support overhang settings. A simple tweak in the form of removing the small guide screw will accommodate a slight vertical tilt relatively to the headshell connector, which stays fixed to the tonearm. It's simple, circumvents the design, but nifty and effective in VTA settings (when actually required).How does that work, spacer shims like the TP-60 or does it use some other mechanism?
I had four or five TD-150s, still keep one around. The early arm is a sleeper, as long as you don't choose low tracking, high compliance cartridges. I used mine with a 30 gram cartridge, the Ortofon SPU GT. Anti-skating is not necessary with 2.5 gram or higher force, imho.
Thank you for the photos, really interesting! R/C car axles could fit the bill. I just double checked my measurements of the spindles with my micrometer, and these ones really are 2,0 mm. (The td 125 and the 320 ones are 3,0).
I wouldn't try any heat on them. I haven't needed any, and I wouldn't want to risk the plastic parts or the hardening of the spindle. Did you try bending your spindle while in place, or in a vice or something like that? I think it's best to do in place, despite the force applied to the bearings, since it should help steer the bending to about the same spots along the spindle as where it got bent in the first place. If yours snapped while in place, I'd guess it was worse off than any one of the ones I've come across.
And sorry once more - I must obviously stop fibbing from memory here. I had the measurement that one must get the error down to wrong before. It must get down to below 0,004 mm, which is why the 1/1000 mm indicator is needed. At least one of the bad motors had an error of 0,02 mm, which caused an audible clicking noise which disappeared after adjustment. It is probably easier to snap the spindle if it is more crooked than that.
I've never noticed that other than with a bent motor spindle. In fact, when they spin they look rather stationary to me, which likely means they're quite perfectly aligned. Why is that? Is the pulley eccentric? Thorens couldn't drill a straight bore?The Thorens pulleys are built with so much slack - especially the 160 ones with the clutch.
Honestly this don't make much sense as a design decision. You know those round motors were used interchangeably with some of the low run TD-165 models, yet no spec differences. The Sonceboz triangle motors are press fit with brass (possibly oilite) bushings as opposed to plastic (likely Nylatron) of the earlier motors. It's just that 'slack' doesn't actually appear to be part of the design. Not to me anyway.
).the 150 is the best if you plan on swapping out the original arm
That's interesting. I'll take a closer look at some 125 and 160 pulleys for that axial joint. It may refresh my memory. IIRC I've never seen it, but I've never put a dial indicator to it either (I might need to grow some thumb nail though, as the thought of using it as a tool had never crossed my mind).
I have rarely seen a 150 in my neck of the woods, but I no longer use my 160 because putting my RB300 or G-707 arm on it would apparently involve cutting part of the metal chassis, which I don't want to do. Maybe one day.
ust two quick notes: As you describe your breaking of the spindle, I think you may have overdone it a bit. I really meant it should be more or less massaged into position. Do not press so hard you can measure any effect after just one attempt, but press it firmly, in several steps, just to achieve a miniscule measurelable correction. The spindle is made of hardened steel, which makes it brittle, but it can be done in small steps. The second last thing you want to do (apart from breaking it) is to overdo your adjustment. The job should take about one half an hour.
With the clutched spindle removed, the unevenness of the rotation of the spindle should be barely notable by your nails, but even a slight wobble can still be within acceptable tolerances. More than that is a bad sign. I don't have my measurements of the 150 spindle around, but don't expect to be able to adjust the wobble of that one at the pulley down to 0.004 mm, since the pulley in itself probably is made with slacker tolerances (I wouldn't advice to remove the pulley, unless @muchachos has an easy method for doing that). But at least now you know what to aim for.
And I would probably try a sequence of lapping films at the new spindle, where the nylon bearing will run.
Thanks for these pointers. I certainly did overdo it, but I had this problem some time ago before sourcing a replacement motor with a 165. Never had any luck with straightening it by hand, but I didn't know this yet! I'm curious what your dial indicator set up looks like, as I do not have this equipment on hand.
This would be between the nylon bushing and the brass bearing mounted inside the motor you mean, with the intention of reducing the running friction? I think I have some mylar sheet around which might work well for this. May see how this works once I get the motor reassembled, or a spindle thrust bearing kit from ebay for support from below to accomplish much the same.
I don't know if you perhaps misunderstood me? The lapping film is the finest grade "sanding paper", with diamond dust, graded for optical and fine mechanics work. Perfect for polishing the bearing area of spindles. (Polishing sintered bushings ruins them, but you already knew that. Only polish the spindle).
Any reason you'd avoid using a basic metal polishing compound for this sort of work? That was my initial plan.
