p.robustini
Hi guys!
I need help or opinion on this one.
I just bought a Thorens-branded new belt for my TD160 off eBay in Germany.
It was about time I replaced the belt after 5 years...
But woth the new one installed, when the turntable starts rotating, it wobbles strongly a few seconds, then goes on rotating normally. It never happened to me before. I setup a couple of TD160s and 165s in the past. I've never seen this.
When I bought this TD160 in 2015, I instantly replaced the belt with a new Thorens-branded one. The bounce was ok, the platter was horizontal and centered. I've never experienced any issue with this deck. So I've never disassembled it in order to adjust the suspensions.
After 5 years, maybe late, I finally replaced the belt and the starting is wiggly and wobbly, everythings vibrates for a couple of seconds, then it is ok.
Maybe I replaced the belt too late and the suspensions got unbalanced because of the slack belt? Will I solve it readjusting the suspensions? Or should I give some time to the belt to wear out? But it never happend before...
The new belt is 496 mm long and 4 mm high. It measures correctly (am I wrong?) and the old one is quite longer.
I bought the old one off the German eBay, too, I think it had the correct serial on the bag, this one has none. I didn't measure the old one at the time. I just replaced it and it worked. Today it just fails to switch to 45 rpms. The new one switches correctly but wriggles at the beginning...
Advice appreciated! ;-)
Stay safe!
Pasquale
Stay safe!
Pasquale
