Edit: FIXED, see post #9. Was colder solder joints on the volume pot!
Here we go, another of my restoration projects, which usually involves 95% me beating my head against the wall and 5% actual progress. WOO
THIS one is a Harman Kardon hk570i. I searched a bunch and didn't find many past project threads about them, so here we go.
The problem is that the right channel is pegged to max volume. The left channel seems to work properly, but at times seems distorted.
Also, it only has done this once, but one time, it was shorting out every 5 seconds or so, causing the DBT to burn bright. Then it would behave, then would happen again, over and over. But I haven't been able to reproduce it.
Here's the bulb under normal operation ... a bit too bright.
Diagnosis done thus far:
So I think I've narrowed the problem down to something in the tone controls or amplifier. Next step is to go through the reference voltages from the service manual and see where I find something funny.
Some of the transistors are in these brackets - I'm assuming to keep them all at the same temp.
Onwards!
- Listened via headphones. BAD RIGHT CHANNEL, MAX VOLUME ALWAYS
- Played via TAPE OUT through my garage receiver. BOTH CHANNELS WORKED PROPERLY
- Deoxited pots & switches as well as I could without invasive surgery. STILL THE SAME
- Removed & tested output transistors (2SA1146/2SC2706). TESTED GOOD (no shorts using the diode function of my multimeter ... but I am still suspicious)
- (Note - this same output pair is used in the Yamaha M70 amp which is neat)
- POWER SUPPLY
- Checked power supply output voltage. MEASURED +/- ~24.5 VDC WHICH IS LOW COMPARED TO THE REFERENCE VOLTAGE (+/- ~42.5 VDC) RAILS, BUT THIS IS THROUGH THE DBT - SO PROBABLY OK (?)
- Note, the DBT is only outputting around 88 VAC ...
Onwards!
(Threaded length should really be longer, maybe like 25mm, since the part with the nut on it had broken off and was MIA.)
