ClayTune
Well-Known Member
Hi all,
First of all, this has nothing to do with my previous post, nor the turntable discussed on it.
I have been having a fairly consistent issue with Rock music sounding a bit harsher and more muddy than Jazz and Classical, heck even hip hop, on my OTHER turntable set up.
Everything is as follows.
Nagaoka cart mp110
Technics SL-Q2 Direct drive turntable. Acrylic mat instead of rubber one.
used protractor, balanced all fours using bubble level as well as on the platter, used test record and blank record to perfect anti-skate. Properly set up tone arm balance (not exactly in this order).
Other gear:
Receiver is Yamaha Natural sound RX-496 using "Pure direct".
And Finally, vintage KLH 7101 speaker set, which are supposed to be some of the better Made in the USA ones.
The cartridge is straight, I always brush it gentle with a needle brush prior to daily usage. I also use a spindle weight to make sure I keep records flat.
A thought I have had is that perhaps it is the OHM setting on my speakers? Difficult to tell, since my speakers do not have an OHM directive on them. Just frequency range and peak wattage listed.
Could I damage the speakers playing with the OHM settings?
Like I said Jazz and classical seem to sound great on this set up. But rock? Gah. I seem to be listening to that more on my computer, not sure what's going on with it.
Again, this has nothing to do with my other turntable or cart which is a linear tracking with P-mount, completely different set up.
Thanks
Nagaoka cart mp110
Other gear:
Thanks
on a continual/sufficient basis!
