Realizing the wide variety of opinions, here’s another one ;-)
Do believe that many systems are capable of reproducing acceptable broad spectrum music, Classical to Rock for instance.
Don’t play much Rock these days, was just telling another member that my music taste has morphed over the years....
Always liked Blues, Classical and Motown type Soul, but tend to play more Jazz and Gospel these days.
However Rock music can vary widely and many of the Rock albums that I still find myself playing don’t differ much from, or even have roots in my current favorites; Led Zeppelin II, Dire Straits Communique, CCR Cosmos Factory, very early Stones, are specimens, could go on and on but you get my point.
From a low end budget standpoint, say something like 1k, believe it’s possible to assemble an acceptable source of broad spectrum music reproduction.
All of the music I mentioned above sounds great on some not too expensive components, a set of Dynaco A35s and a Rek-O-Kut turntable are examples....
This particular system has some moderately expensive pieces of gear, preamp and amp, but other much cheaper preamps and amps exist that acceptable replacements.
In my experience the cartridge and the preamp are critical parings when it comes to faithful music reproduction. Even those can be sourced at reasonable cost, many 90s era preamps are good quality inexpensive items with phono MM capabilities, and it doesn’t take a high powered amp to drive those Dynaco speakers.
A wide variety of cartridges are out there for < $100, Pickering XV 15, Shure M44, Stanton, on and on....
The Tonearm might bust the budget, but I’ve seen used turntables sold with great tonearms go at ridiculously low prices. Alternatively items like the Syntec S220 or Denon DA 50 are examples of “good” tonearms for not much money.
Really enjoy my relatively inexpensive system, in fact it’s listened to the most....
With all that said, my other system, that costs much, much more, does sound better, but there is a point of diminishing returns, where the order of magnitude of improvement is harder to discern....
Not sure what you’re budget is, or what you might need to add/replace in your current gear but there are and will be some great suggestions from the members here—
You just have to use your discernment in which advice to follow
VR
Andy
