dnewma04
The Healer
One of the Iron Laws of Audio! :yes:
It takes a real genius with copious amounts of bondo to pull it off.
Hey sm, LOVE the "Enough Rope" article @ your link. More enlightenment
and yet more things to ponder. ANNND there's things in there that dovetail
nicely with other things I've been thinking/wondering about, especially
regarding best ways to house a mid-bass driver. The 18" tube described
looks a lot like that in the likes of the IMF TLS 80 and the ESS AMT 3, for
instance. But ever since I first read ESS' literature
describing their tube as a "transmission line" I've been going "hmmmm..." -
and then this article describes using a real TL loading for mid-bass driver
like I'd been pondering. I'd been wondering how that would compare to
B&W's tapered tube or sphere-into-cone sub-enclosures. I'll be rereading
that article a few more times and looking a lot more closely at Fried products
to see what else I can learn.
Oh, good to know about the Yahoo TLG, too, thank you.Didn't know about
that, so I will be looking into it. I'll be sticking to drivers that are zippy
enough to blend well with the big Heil AMT's in the neighborhood of 2.3 K.
http://www.scribd.com/full/15802035?access_key=key-2wxihnbgss6auvhs321
Bud's writings explain it the best
The particular issue with the Heil AMT and it's woofer is that there are few woofers than can get high enough in frequency in a two-way alignment and maintain a good transient speed in the lower end (enough to keep up with the AMT). I know of one user that has a two-way Heil setup but he uses a woofer that is no longer in production.
I use the AMT with a midrange horn driven by a compression driver so it's transient speed is close. The AMT is crossed over quite high (from 7khz -->9khz, depending on my experimentation) Under these is a 15" Altec woofer in an MLTL alignment. I like the MLTL better than the original BR cabinet because it removes the hump in the lower frequencies and delivers a very mild rolloff to the nether regions. The tradeoff is that it requires a large cabinet, 16 cu. ft.. If I was looking to rebuild the Heil cabinet and bottom end, I'd be looking for a quality woofer that will mate well with the other drivers and the enclosure could be any of the three discussed. It sounds like you are not liking the vented cabinet so the TL might be your choice. Good luck with the Heil redo!
Two things I don't have much experience with; and I'd like to hear
any opinions on their general similarities and differences as far as
their actual sound goes. Subjective and un-scientific as this is,
I'd love to hear from anybody that has listened to both. (Or be
steered to a thread on it that I've missed.)
What I'm out to build is a nice, no-subs-needed, 2 channel, music-
only home system with something like a single 12" or twin 10's @
side, most likely 3-way & tri-amped. Driver selection is pretty well
covered - what I need to decide is if it's worth the extra work to
scare up a TL design when I already have a nice design in hand for
overdamped BR. (The extra fab difficulty would not be an issue.)
I don't need stupid-deep subsonic HT rumble, just effortless, musical
bass. Any feedback is greatly appreciated.
What does "BR" stand for? I have never heard the term.
-k
It threw me off too, but I think it stands for "Bass Reflex". I had to think about it for quite a while before I came up with that, which I think, but don't know for sure, is it.
Oh boy, are you guys in for some alphabet soup if this thread keeps going.
Yes BR for Bass Reflex is a pretty common consensus
I write ODBR when I get tired of writing out OverDamped Bass Reflex
TL is common for Transmission Line
And then with hybridized TL (or mongrelized some would say), the fun really begins:
Like MLTL, Mass Loaded Transmission Line (my best take on that, FWIW, is,
kind of a regular TL firing into a ported box - and I make NO claims there's
not a better interpretation - I'm a noob to the whole TL & variants thing)
I assume you know about the most important T&S (Thiele & Small) parameter:
WAF (Wife Acceptance Factor) - an invert function of WUAF, or
Wife Un-Acceptance Factor, which is DEFINITELY measured in dB.
Or so I've been told.![]()
