Hi,
FWIW I understand the AMT 3 with the AMT tweeter, a 6.5" mid
and two 10" bass units all versions had PR's / ABR's fitted.
The nearest to this is venting and its not remotely like aperiodic.
You can't choose a method of bass loading on its own, it has to
go hand in hand with the driver choice, the sensitivity, SPL and
bass extension requirements than can be met for an acceptable
enclosure volume.
DIY'ers cab build very big boxes for relatively small drivers to
extract the best performance out of them but commercially
that is suicide, manufacturers used optimised compromise.
IMHO for a given box size nothing gets close to an overdamped
vented alignment as long as the tuning frequency is low, near
the audible limits of low bass due to loudness curves, and
it becomes effectively the bass limit of the system.
for a given box size, nothing else will dig that deep
and
produce max SPL's down to that point that are comparable.
Good bass extension is no good without clean SPL capability
to back it up, and that SPL requirement depends on room size.
People wiil say "so and so" is better. It isn't. Not when you
you compare all the factors involved in reaching a compromise.
You can design an overdamped vented box that is around
50% bigger than a butterworth sealed box that has a quasi
first to second order roll-off down to the tuning frequency.
After that group delay and response goes west, but it
doesn't really matter if its tuned very low.
The vent or PR progressively reinforces the bass drivers output,
~ doubling it over the low bass range and quadrupling it at
the low frequency cut-off point, it slaughters a sealed/aperiodic
box with the same divers for extension and output capability.
TL's can do something similar and they can be arranged to
take bass extension for a particular driver even lower, but
thay are usually much larger and more complex to build,
Or for the same box size you need a smaller, less capable
bass unit, so you get extension but lower SPL capability.
Waffling on about this and that arrangement being
better than another arrangement is just waffle.
Done properly they all work, and they all have limitations.
The art of optimised compromise is choosing your limitations.
rgds, sreten.
Take this bass driver, volumes are per driver :
http://www.europe-audio.com/Product.asp?Product_ID=7958
The classic vented box cuts off in the 30's and will sound like it in room.
The larger sealed box will sound marginally tighter than the smaller.
Note the smaller overdamped vented closely matches the 0.61
roll off at a deeper level (due to port output) right down to 20Hz.
What you can't see here is the further extra power handling
and SPL capability centred on the 22Hz port tuning frequency.
You may say what is the point of discussng 20Hz when its 10dB+
down. Room gain and / or active bass EQ is my answer to that.
FWIW the classic vented alignment wil go louder on most material
than the overdamped box as its tuning is higher. the overdamped
box is simlar to the sealed boxes capabilties higher in the bass.
