...... Now who would be crazy enough to set those out?
I'm not really a huge BOSE fan, but those things look very insane! They also look very menacing when all the speakers are showing. Now who would be crazy enough to set those out?
......Those who have them, say they put out some seriously loud sound.
Use foam, not cloth.
A family friend brought me a pair of 901 series II (and equalizer) to restore. He'd found them in a thrift store for $20. Missing one front and one back grills, they smell like a damp ashtray, four of the drivers need replacing and the other 14 need refoaming. The only redeeming quality is that the wood isn't too bad.
My recommendation to him was for me to refoam the 14 drivers to clean up the parts and part the things out. To me they're not worth all that work - to enjoy or for reselling them. While I'm a confirmed Bose hater, I've owned 101's, 201's, 301's, 501's, 901's and several of the Acoustimass/Cube systems but they just don't do it for me. But that's just my opinion.
Different compliance and damping/absorption of the wave when it reaches the edge of the cone.
I've refoamed two pairs of 901s for a friend, and its a major pain, even if you don't remove the drivers. So I'm keenly aware of the downside of foam. But designers use it because of its acoustical qualities.
Cloth can be treated with silicon compounds and such to give it better damping, but that silicon or whatever tends to migrate downhill over time, at the top, soaking the cone -- is that good? -- and, at the bottom, dribbling off, so its damping properties are lost. Not sure that's an improvement. But its better than the cone treatments that turn to rock -- I've had several Jensens that were unuseable for that reason -- or cone treatments that dry out and crumble off -- KLH and AR, for example.
I am not sure why people who perfectly happily change the oil in their cars a few times a year have a hissy fit when they have to refoam every couple of decades.
Oh believe me they do indeed. With the right/correct/placement setup along with the right powerful amplifier and matching Bose Active Equalizer they'll kick out that sound.
Edit**two important things to keep in mind...1) Never use 901's for outdoor listening and 2) don't ever try them without the active equalizer because then you'll be very disappointed.
You live in NY. While you aren't absent of high temps, we have temps in the high 90's for months at a time. Living in the high desert of CA temps often reached 120. This does soften the treatment and allows it to run. Keeping in mind this is all subject to the temps inside your house, and not just because it's hot outside. Those that keep comfortable or moderate temps aren't likely to run into this issue. Pun not intended.So I guess foam it is. I've resealed the cloth surrounds on all my KLH woofers with the correct sealer vintage-ar sells. The original sealer was mostly gone after 40-50 years, but there was no run off on the drivers or dribble at the bottom as you describe. I have seen this on JBL's though.
GD70 -- I was making a distinction between cloth surrounds damped with silicon compounds which dribble (ADC, some CTS, Leak Sandwiches (these surround also slide down the basket) and others), and cloth surrounds with different compounds that dry up and crumble off (AR, KLH etc.). Leaving aside the compounds that completely seize up, which I've seen on some Jensens (other identical drivers have completely supple surrounds) and an Oaktron.
My point is that no surround material is perfect, and none last forever. But who expected any speaker to still be in use for decades, and in some cases more than half a century, after its manufacture?
Now that I think about it, there is an astonishing enthusiasm for recapping (not an issue with the 901s at least until you lay your hands on the control box) which contrasts oddly with the indignation about refoaming. Both may be necessary (though the need for refoaming is at least easier to diagnose with certainty) and both are in the preventative maintenance category. The use of inexpensive electrolytic capacitors is basically price driven whereas the use of foam is tied up with what the driver designer is trying to achieve soundwise, but some people seem to get pretty upset with the latter but not the former.
Have you tried using alcohol to soften/remove those glue residue stains?
