new2ltrk2009
Member
Nice save!
Scott's Liquid Gold is a product with some solvent-like qualities that has removed absorbed tape residue for me in a few cases. Might work for you.
I want to find some LSTs in the garbage.
The sticky residue is gone. I used Acetone, took it right off. The wood absorbed the moisture from the tape glue over time. So I have to take it down by sanding it off.
I'll try some alcohol just to see if it helps though.
I own AR3a speakers. Having blown tweeters or mids in an LST is a scary thought. 6 mids altogether? Yikes! I'm sure they must sound amazing. Those AR mids are impressive.The LST's I found on CL, the 901's I found. My best garbage find so far!
If you don't have one yet, should get a Series III or IV EQ to go with those when you have them completed. It's positively amazing what the EQ does for any of the 901 speakers.
OoOOooooO, sanding veneer. I just love sanding veneer. Acetone? That's weak stuff, evaporates before it has time to do anything. I generally use a mixture of toluene, xylene and isopropyl alcohol (epoxy cleanup solvent). No ketones though, don't need those. A good swipe of that stuff with a paper towel and you're done.
xo, Biggles
Those cabinets look FANTASTIC. Great job bringing them back to life! :tresbon:
The acetone worked pretty quickly. I've used the stuff for 40 years.
Do you mix up the stuff you use, or is it commercially available?
I finished sanding the top, did a light sanding on the face strips and sides. One side had some kind of splatter which also stained the wood a bit. I used my xacto and carefully scraped the surface , then sanded, then used 0000 steel wool on all the surfaces. I applied the Watco Danish oil, natural, and the wood looks outstanding! The tape residue stains are gone!
On to the 2nd cab. Here's a few more pics.
Final sanding and oil application.
This was the side with the splatter restored.
Other side was good, but oiled.
Fantastic job, man. Looking great.
