Tone Controls?
But to your point on talking about it, it’s the same with everything on here, receivers vs separates, vintage vs new, horns vs no horns...
Not sure what your point was :rolleyes:
:beerchug:
Really? I thought my point was fairly obvious.
Rig and room dependent here. My Mcintosh C33 preamp is just what doctor ordered to tame my khorns.....does anyone here run their khorns flat:dunno:?? But on my other 2 rigs there are no tone controls to fuss with and I don't feel the need for them.
If it is in the signal path, anything goes as long as you like the sound. Personally, I seek objective accuracy so short signal path and no tone controls works for me.
A widespread “argument”, after that a sound, being transformed into the electrical signal in the microphone, having passed through microphone amplifiers (and for low level sound sources, also through a microphone transformer), then through line amplifiers, audio mixing consoles with their stereo panorama controls, phase shifters et stereo balance controls, filters (high-pass, low-pass, “presence”, “voice filters” etc.), studio equalizers, dozens of DACs and ADCs elements, then through electromagnetic transformers in tape recorder heads, electrical frequency response correction circuits in recording amps, then through electromagnetic transformers in tape recorder heads, electrical frequency response correction circuits in playback amps, then, in the case of vinyl records, through correction circuits forming the standard cutting characteristic for cutter heads, through transformation of the electrical signal into mechanical groove form by the cutter, then the reverse transformation of the mechanical groove form into modulation of the magnetic field by the stylus and the cantilever, then into electrical signal by the cartridge (after a MC type cartridge, also through a step-up transformer), the reverse correction circuits forming the standard playback characteristic for cartridges, then again elements and elements of DACs and ADCs, emphasizers and de-emphasizers…
But, after all this, adding a tone control or an equalizer by a listener is a “breach” in “short signal path”?!.. Oh, Boy!
:beerchug:
His point was, he likes to tell people he keeps his temple "pure and clean" whenever he gets the chance, like the people who tell you they don't own a tv.
Live, real time sound is by definition the reference. If you accept this, few to none of the devices you mention are in the signal path. Why should I accept any of them when my preference is for sound as close as possible to the reference? For me, the answer is as little as possible. Your list is lengthy (pun intended). Some of that is necessary to time shift. Some of that is dictated by venue, that is the recording location has some problem that needs compensation. Some of that is driven by commercial imperative such that the track needs to play on crappy car stereo speakers and earbuds. How much of this can be eliminated with proper setup and line level balance? If you have ever noticed a bad recording and wondered how much more you would enjoy the track if this was not the case, you would understand my point of view.
Anyway, do you use the bass/treble controls or an equalizer as part of your normal system setup?
Won't touch 'em. And I don't need 'em.
But one thing I've noticed is that over the years, the higher I've moved up the equipment chain, the less I needed them. When I had a preamp with tone controls, I found I rarely used them anyways--things never sounded right to me with tone controls engaged, unless the attached equipment was crap. Graphic EQs throw all sorts of phase and response anomalies into a system, so, I avoid them like the plague. Parametrics are what many studios use, and I would go that route if I needed one, but only as a total last resort. Digital EQ and DSP? Too many digital artifacts for me--once I heard them, they cannot be unheard. My room does have issues, but those need to be cured with room treatments, speaker placement, and moving/changing the listening position first. (You can also guess I'm against "room correction," as all it does is fix the music in one single spot in the room, while throwing all other listening positions out of whack.)
Just my two cents worth and as always, your mileage may vary. (If it rocks someone else's world, that's fine by me! :) )
Lol, thanks all for the discussion! I gather that threads like this can generate a certain passion and loudness at times.
A
