Lexar
Member
Hello,
As being total newbie with turntables with interchangeable tonearms, I would like to ask 2 questions.
1.) I'm considering to buy and install Jelco SA 750 tonearm to my forthcoming Luxman PD 441 turntable. By then do you think that I could only use Jelco SA 750D (effective length 229mm). Or maybe also Jelco SA 750E (effective length 255mm)? Or even Jelco SA 750L (effective length 305mm)? Just asking those as in that turntable's manuals (Vinylengine)....there're listed also some bit longer tonearms like Micro Seiki MA 505L (effective length 282mm) and SME 3012 (effective length 308mm). Or will those numbers alone tell enough in the end?
2.) With that turntable I will get so called TP-MH armbase. It will suit for following (old) tonearms: Micro Seiki MA 505, SAEC WE 308, Grace G 704/714, FR 64 etc. It has round hole plus 6 radial notches (for 3 screws of mentioned tonearms?). See the photo of similar armbase:
Do you think that I could install Jelco SA 750 tonearm easily to that arm board? Does Jelco tonearm need a arm board which has 30mm round hole, or? Based on photos only, perhaps that TP-MP's hole could be about the same size?
