Hi everyone,
The turntable that I have is a TEAC TN-300SE-WA. This is my first turntable so I’m not sure if this is common. I noticed that once I lower the tonearm, it slides towards the groove. It seems to catch the groove perfectly and it starts fine. However, It’s just the sliding that doesn’t feel right.
The cueing is up to the user to control the drop and its speed. Even if I drop it really slow, the same thing happens. I took the turntable to a local shop to see if I set the weight and anti skate wrong but he said I set it correctly. I showed him one of the records I was playing. He said the outer part on the record where there's no music is too lifted up which is why it slides. However, It seems to happen on every record that I play. Sometimes the movement is more drastic than other times.
Could I be setting the starting point too far towards the edge?
Any help is appreciated, thanks!
