Holst
Addicted Member
Mopic5 said:Take a deep breath … Apparently, there’s a bit of more complex geometry than the easily visualized effective length/swing arc going on here. While swing arcs of both type pivoting tonearms of equal effective lengths are identical. The tangential relationship of the stylus to the groove (that ever changing axis off 90 degrees as the record tracks across the record) is influenced whether its offset (cant) is at the tube end or back 4 to 5 inches.
Take another deep breath… This, in turn affects, not only the tracking behavior of the arms but also each of the two type’s dependency on anti-skate. The straight arm needing much less than the S-curved offset (Rega users will attest to this). Some have it that a 12” straight-arm can perform well enough (with a spherical stylus) to dispense with any skate compensation completely.
Now, I started this with “apparently” because I am spatially challenged and I need wood mock-ups, compass arcs and not words to visually anything beyond the simple plane geometry. So I’m not convinced about this, nor am I, in any way, prepared to defend it. But this is out there and I’m trying to keep my mind open it. I’ve asked for illustrations.
- Mario
I had a book once, in the 70's, that was basically geometry for Audio salemen. It was put out by Pioneer. Thus said, a tonearm with a pivot at said right angle, as in restorer-john's example would be pushed to the right, pivot's eye view on a straight arm. On an "S" arm or an "L" arm the stylus would be pulled forward across the record (Picture it in your mind, I don't have the graphics anymore) thereby negating or lessing the need for antiskating devices.
Damn, this hurts my brain.
Tonearms are nice, records are good, me like tonearms and records.
Records, records, records......
There, I feel better.
This again was used as a sales tool, by Pioneer, who sold turntables, with "S" shaped arms, that had antiskate devices. Did I mention the PL-71 was pretty. We had one in the store, "S" shaped arm. I took home the Technics SL1100a, I got a discount for working there, it had an "S" shaped arm.
The headache is going away.
As restorer-john said, the "S" isn't just to look pretty, I've always really likes "S" arms. I'd like to own one again.
The SME vertical axis (SME 3009 SII) is approximately 30 degrees displaced from perpendicular. Even with such grossly misaligned bearings, the effect on azimuth due to a change in stylus height of 1mm is less than 0.25 degrees. While this effect may be worthy of consideration when choosing between tonearms using aligned or misaligned bearings, the effect on azimuth of an alignment error of a few degrees (which would be typical of selecting an alternative linear offset to the recommended value) is absolutely negligible.
But it is very obvious that other types of arms didn't just happen either. Somebody put a lot of thought into it.
If it works, it's good.
The SME 3009 SII is pretty too.
