Raccoon1400
The sencore arrived today. The tuning gang is stuck, it only moves a little bit. I think the grease in the bearings has clumped. Does anyone know how to fix this?
I unstuck it. I sprayed a bit of deoxit in the bearings and it moves now. I also found 2 leaking caps.
Reding all these posts about aligment I've noticed few times was recommended that plastic or non metallic tools are needed. I assume screwdriver, hex key and such. Where would one find such tools?
Thanks.
I've done other work on amps like resetting specs, recapping, replacing outputs. I'm studying engineering and have used scopes and function generators at school, so I have some idea what I'm dealing with.
I will chime in, not as a tuner expert, but someone that has taught himself how to properly align certain tuners that matter to me, over the past several years.
JUST DO IT!
Read the tutorials, pick up something like an SG-165, get an inexpensive set of plastic alignment tools, find a reasonable candidate for an alignment that you can also find a service manual for, and get engaged. Like many things in live, doing it will teach you way more than reading about doing it.
This is not rocket science, and lives are not lost if you get it wrong the first time... or the second, or third.
The learning curve certainly exists but it's fun to climb and there are plenty of experts around here to ask for assistance as you climb it, if you need the push up.
John
P.S. Never worked on a Rochester injection system but learned over the years how to keep Bosch K-Jetronic systems and the mechanical injection on my M130 Mercedes engine working. If you have the car, a manual, tools, determination and patience, it's going to happen. Tuner alignment is much the same, IMHO.
I have an hk 430 that I want to start with. It looks like a good simple one to start with. I have a couple questions.
The service manual for the hk says "connect signal source to a loop placed to radiate signals into AM ANT LOOP STICK." How do I do this?
I'm not clear on how to setup the sencore.
The hk service manual says "AM signal generator modulated with 400Hz at 30%"
The first step says "455kHz of sweep generator AM sig. gen." Then 530kHz, etc...
I see I set the am modulation switch to 30%. After that I'm not sure. The AM tuning dial only goes as low as 526kHz.
The sencore manual says to "Connect the SG165 speaker loads". What are these? How do I connect them? Are they the alligator leads in the lead compartment in the back? Or would it be better to use my scope for analysing the output?
Did you get the manual for the Sencore?
