Toslink and receivers ?
Lossless
I searched the web hi and lo for an answer of when fiber optical Toslink was first introduced into home receivers. I understand Toshiba invented it to pair their CD players to their receivers, but I never found any toshiba receiver with Toslink. Any clue what year and what amp or receiver first utilized Toslink optical inputs?
My guess would be around 1989. Sony ES and Mitsubishi receivers/amps were the first units I saw utilizing Toslink connections. Toshiba invented the Toslink connection, but I'm not sure what exact purpose they had in mind for it.
That is good to know. My main reason for asking the question is because my 1989 Fisher RS-Z1 has Toslink and a Burr Brown internal DAC. That would make this receiver cutting edge for the time period. :music:
TBH reading the article with all the possible limitations of Toslink vs. SPDIF makes me wonder why it was utilized. It apparently required a lot of refinement before it was comparable to SPDIF and finally requires ; in actual application the practical limit was often under 5 meters, constructed from very high purity quartz, a highly polished and properly fitted termination, degradation of performance due to even mild bending of the interconnect assembly!
All these and other issues mentioned in the article make me want to throw out the inexpensive optical cables and replace them if practible with SPDIF which can be as simple as using any quality audio cable.
Toslink was common prior to 1989. Plenty of integrated amplifiers, digital preamplifiers, CD players employed the TosLink connector as well as coaxial. It came into being in 1983.
Your Fisher RS-Z1 is part of a series, including some rare power amplifiers. Basically, Sanyo wanted as a last ditch effort to stay relevant, some profitable top models to compete with Sony, Nakamichi, Akai, Pioneer, Technics, Denon etc.
And in incredibly rare CD recorder using the magneto optical system. I've never seen one anywhere:
The exterior of the Z series is more impressive than the interiors. The CD player for instance looks great but apart from an outsourced D/A board is extremely cheap on the inside. It was all about marketing. Notice the PCM-58 is just the lowest tier grading with only a single MSB trimpot at a time when other brands were using at least selection K, J or S with up to 4 MSB THD adjustments in their top models. Here's a few shots of the insides of the CD player pictured. IIRC, there was also another model CD player produced in that series too.
http://lampizator.eu/LAMPIZATOR/REFERENCES/fisher_ad-z1/Fisheradz1.html
The exterior of the Z series is more impressive than the interiors. The CD player for instance looks great but apart from an outsourced D/A board is extremely cheap on the inside. It was all about marketing. Notice the PCM-58 is just the lowest tier grading with only a single MSB trimpot at a time when other brands were using at least selection K or J with up to 4 MSB THD adjustments in their top models. Here's a few shots of the insides of the CD player pictured. IIRC, there was also another model CD player produced in that series too.
Well fortunately I don’t own a RS-CD player as I see it has cheaply made innards. The RS-Z1 receiver on the other hand ROCKS!!! :rockon:
It is SPDIF, only using an optical, rather than coax, bearer.
To achieve good jitter performance, you need fast edges and low noise. Slow LEDs, lossy, smeary, polymer fibres and cheap receivers don't give you fast edges. All those things can be improved. Led technology has improved significantly since 1980.
Something like this?
I switch back and forth between the Toslink optical and 75 ohm coax inputs and the coax seems to have a better sound. The only disadvantage I find with the coax is ocassional electrical interference from appliances.
I think Toshiba was anticipating satellite digital radio broadcast to utilize optical inputs.
At a weight of 46 pounds with a big 'ol pair of Nichicon caps, giant transformer and some serious heat sinking, it's built very nicely indeed.
I was thinking more about the transmitters and receivers than the cables. And the clock regeneration/
I wouldn’t classify a Fisher RS-Z1 as a “ cheap receiver”
What is that BA-Z1?
You also stated that Toslink was common in receivers prior to 1989 and plenty of receivers and amplifiers used them. Could you please be more specific on a particular stereo that utilized this technology prior to 1989 for I have not been able to find any.
Go research the top models from just about every major Japanese manufacturer. Putting D/A converters in amplifiers and calling them Digital Amplifiers was all the rage.
I have a pile of them myself:
Pioneer A-91D (1988)
Akai AM-M939 (1987)
Sony TAF-303ESD (1988)
Sony TAE-77ESD (1988)
Yamaha CX-1000 (1987)
Denon's DAP-2500 and 5500 preamplifiers (1988)
Akai AM-M939 (1987)
How come none of these are available in the United States? They seem to be a dime a dozen in Germany? We always seem to get the crap.What’s gives?
The Yamaha CX-1000 and the Sony TAE-77ESD were sold in the US in decent numbers. I know there were A-91Ds sold in small numbers in the US.
Those models were just ones that came to mind or are floating around in my loungeroom. There were plenty, trust me. The Japanese economy was going gangbusters and R&D budgets were massive. Then it all crashed and by 1991 all this stuff was being dumped on the world markets cheaply (in real terms).
I'm not sure who built your Fisher (Sanyo) unit, but it's likely it was an OEM, based on the internals of other pieces in the series I have seen. If you pull the covers and take some closeups of boards and components, we can date it more accurately and possibly determine who actually made it.
