Dallas Bland
Greetings all.
I am new to vinyl and new to the forum. I have recently pulled out my old Kenwood KD-2070 which I have had packed up for the last 20 years or so. I lubed the mechanisms and cleaned the pots etc and got it working quite well. I thought. It seems to skip really easily - I have to walk past on tippy toes for it to not mistrack from my footsteps so it is veeeery sensitive to vibrations. And I occasionally hear distortion in one one channel. It seems to cut in and out at different times.
I have read through a bunch of threads but and although there posts which have helped, I thought I best open a new thread as my issue may be more than one issue.
I looked into balancing the tone arm and the anti-skating adjustments. This model uses the antiskating weight as opposed to a dial, but the weight is missing.
In balancing the tone arm I don't know the recommended weight of the cartridge so I am levelling to zero then adjusting to 2.5 as an guess. In not having the correct anti-skate weight I attached a 2.5gm fishing sinker on a fine thread. All this is taking a guess at approximate weights.
After all this the problems are just as bad as before doing any adjustments. It seems to have made no difference at all.
Does anyone have any advice on how I should move forward with this? Is the weighting so crucial that being out by .2 or .3 of a gram will make this much difference? Is it more likely to be the actual stylus as I have no idea what kind of condition it is in.
Any guidance would be much appreciated.
Thanks all
Dallas
Thanks all
Dallas
