Pulled Q5 to test via diodes function show good.. Q6 is bad, no voltage (not sure it was shot when sparks fly or before). resistance between pin16 to ground (chassis or pin15) show around 100R. This unit I got from someone saying the TF is bad, need replaced and there were no fuse in FU5, FU6. So put in the new fuses to check around the TF but it keep blowing up FU5 & FU6 fuses.
