lieutdan
I'm currently rebuilding the power supply board on a Sony Str-6045 and have come across a transistor which seems to be used strictly as a diode via the Emitter and Base, with the Collector left disconnected. It is shown on the diagram as a 1T244 diode.
Would this have an advantage over using a regular diode/zener diode? it seems that using a transistor this way should function somewhat like a 6-7V zener. Could I replace it with a zener, or even a 1n4148?
