Hello,
I have a Traynor TS-200, Yorkvillve Sound LTD., 1978. There are some electrical issues I am sorting out for the owner. There are 2 large filter capacitors that look original to the build. They are MEPCO/ELECTRA, 3110JC123U075, 12000MFD, 75WVDC. The original electrical schematics that came with the unit shows a different spec for the caps - 6000uF @ 75V. Is it possible this a factory install and they just put in what was readily available? I am basing my assumption that it is a factory install due to the vintage of the capacitors and appearance of the install.
Whether it is or isn't a factory install, if you were to replace these caps what would you go with - what is installed and has apparently worked for years or something closer to the diagram specs? Thank-you.
