Hello, I am looking for recommendations for tri amping my JBL 4435s.
After considering using a modified passive crossover at length with Zonker, I was advised by an engineer friend of mine to use an active solution and to tri amp, to remove inefficiencies and losses of the passive configuration. Truth is, I no longer trust my crossover/L pads and building a new crossover is expensive.
I use my system for listening and moderate volume dance parties. What I have noticed with my speakers is that at high volume, the mid range woofer starts to bottom out on both speakers, while the low range woofer does its job perfectly well. Which brings me to my plan.
I am considering using a K231 crossover:
https://sublimeacoustic.com/products/k231-stereo-3-way-active-crossover
with 2 chips configured for
40hz-100hz/100hz-1000hz/1000hz+
one with slope 12db
the other with 24db
Opinions much wanted! thanks
