stanwebber
i have a couple denon dp-7f turntables that i've never been satisfied with. the tonearm and motor seem good enough, but the rest of the build quality leaves something to be desired.
i often switch out cartridges multiple times during lengthy listening sessions so p-mount is a must. i've always preferred dynamic over statically balanced tonearms, but the only other p-mount turntables i've come across in this configuration are linear trackers which fail pretty miserably with off-center records.
i'm considering some mods to the dp-7f, but really would prefer starting over with a completely different unit, but i'm kinda coming up empty. does anyone know of an alternative turntable with the following criteria? thanks.
tonearm:
- p-mount
- pivoted (non-linear tracking)
- dynamically balanced
motor:
- direct drive
- quartz controlled
tonearm:
- p-mount
motor:
- direct drive
- quartz controlled
