The jumping point!!ok that makes more sense. Its a bridge, and then half a bridge. Full current through the two diodes going to ground, half through each pair with a + output. Exactly why they did this is unknown but at least I understand it now.
what would you even call half a bridge? A plank?
Might need to see the whole schematic, and also need a better understanding of what "has 16 watts dissipation on the right channel of a 6bq5 power tube." means.I located a schematic. Some one evidently removed three resistors the 150k on the schematic are they were never installed.
Yes single ended with a headphone amp and a precut.Is it a single-ended amp?
This 6-diodes power supply is unusual for a 6BQ5 amp.
I dont know if its legal to post the schematic. Well the right channel 6bq5 is running around 65 milliamps.Might need to see the whole schematic, and also need a better understanding of what "has 16 watts dissipation on the right channel of a 6bq5 power tube." means.
Yeah, what an odd way to make a rectifier setup. A complete schematic is needed to avoid speculation.The output of the two sets of diodes should be the same voltage since they have the same AC input and filtering setup. If they are actually different, I suspect there is some other problem. Open filter cap maybe, that makes for low voltage.
Seems more likely two plate supplies with the idea to isolate it per-channel. I'm guessing the 150K are bleeder resistors since they can't pass meaningful current at those voltages.
Posting a schematic will be fine. Really, it's the only way to figure out the idea behind the diode setup in the power supply.I dont know if its legal to post the schematic. Well the right channel 6bq5 is running around 65 milliamps.
Otherwise, the manufacturer's model number would be helpful.If the tube is running too hot, and you have tried another tube, then it's to do with the way the output tube is biased. Could be a failed coupling capacitor, could be a failed or failing bias supply if fixed bias, etc. It's a guessing game without seeing the whole schematic, and I have no reason to believe that it's the diodes you have shown causing the issue.
Agreed
