BDR_23
For the past few months I have been building a record cleaning machine. And now I'm pretty much "done" but having problems with the vacuum stuff. It keeps sucking up water into the white pipe and soaks the wood bulkhead the vacuum motor is clamped to. There never seems to be water on the inside of the impeller housing and no water sprayed through the vents. Today I glued two pieces of plastic to the intake of the white pipe and exit of the clear pipe, each with holes drilled in it to restrict the airflow. I had some success and the water stayed in the tank (even when it is sucked up most still stays in the tank, fyi) but I had issues with suction. Two rotations were needed to fully suck up the water, I wanted one. So I drilled few more holes on each piece and tested for wetness after each. Eventually it started sucking up water again. I'm not sure if the arrangement is correct for fluid collection. Tried finding info how RCM manufacturers do their system but found nothing. Any changes to stop this problem? The vacuum motor is plenty powerful but stopping the water being sucked up the white pipe and not handicapping the sucking power is puzzling... Over $200 has been sunk into this thing. Managed to clean ten records during my testing tho.
The white piping you see is about 1 3/8"/3.5cm ID. Plastic container is 9"/23cm tall and 5"/12.7cm wide. Clear pipe is 15/16"/2.5cm ID. The end of the clear pipe sits 1-3/4"/4.5cm from the bottom of the tank. https://www.grainger.com/product/AMETEK-LAMB-Vacuum-Motor-2M429
