All 0 ohm resistors read 0 ohms.
I'm trying to figure out why you are saying that the problem likely resides before the board when the signal coming into the board is fine. That's the first image I posted. Also, the output of the op amp is fine, which is the 2nd image I posted. The signal goes from the BA312 through several things and winds up bad at HE03, from what it appears to me. I'm just unsure what would be clipping the bottom of the signal between those two spots. As I said earlier though, I am suspecting a capacitor, since it builds up distortion over time, and even faster if I turn the bass knob all the way up, and I have tested a bunch of the capacitors I think are inline, and they seem to test okay.
The distortion in those images above is with the bass control about half way up. If I go all the way up, I lose signal completely.
