Troubleshooting a variac
Larryhere40
I have a elenco xp-800 variac! Doesn’t adjust with the DC voltage. Works on all the others stays at the top DC voltage and doesn’t go down when you turn the knob replaced a couple transistors and a voltage regulator, not a lot of other stuff in there. Any ideas on what would cause that? Capacitor? Any advice would be great for what to look for. Thanks.
if this is the schematic, not a lot of parts.
I'd check the power supply but my variac is an old school.
This 40 to 50 years old! No transformer or anything, just a big giant poinometer kind of thing used to change the voltage on both AC and DC from the wall plug of 115
Is that 8 pin dip supposed to be the regulator? Is it a variable regulator?
perhaps that transistor in the heat sink is shorted. Unless that’s one you replaced.
Rob
There is definitely a variable autotransformer (aka variac) in there. That's the coppery winding gizmo hooked to the bigger knob.
That variac (T1) provides the variability for the straight AC 0-120V output and through the step down (T2) the variable 0-40AC and varies the AC input to the DC power supply for that adjustability too.
  • Like
Reactions: mbz
Have you put a load on the DC output to see what happens? That's a pretty big capacitor and maybe holding the high charged voltage without a load.
