Larryhere40
I will try applying the one amp current tomorrow and see what happens. Thanks so far.Sorry.. 1A current on the DC output?
Looking at the schematic I see there is a 470 ohm 2 watt resistor (R260 that is connected (shunted) between the rectifiers output and ground and that should drain, if not open, and keep the the big main filter cap`s DC from floating to any higher voltage level than the desired dial selected level.Confirm if you actually loaded it down rather than just reading or measuring the voltage.
Yes, I understand your reasoning, as I observed by looking at the schematic about the metering`s circuitry`s requirements, a set of alligator jumpers connected to a table lamp, etc. with a medium wattage incandescent bulb fitted & it`s power plug connected to the DC output would easily be household readily be available and used as a quick test to pull the main cap`s voltage down if R26 is in fact open with the feeding variac turned all the way down.That's the unstated, sly aspect behind my question. There has to be something to discharge the cap. The resistor should, but so would a load. Point being, does an actual load on the DC output change the symptom.
Bear in mind this appears not to be a regulated power supply. All the ICs and such are for the meter display scaling and function.
This ^^ calculated 30~40 sec. time constant would be for a fresh up to snuff cap.Even with the 470 ohm resistor across the cap, it could take an unexpected long amount of time for the voltage to drop.
If you dial it up to 28V with no external load, then dial back the adjustment to say 14V, if I did the calc. properly it could take something like 30-40 seconds for the voltage to get down to display 14V just on the internal resistor alone.
If the OP is expecting the voltage display to respond quickly/immediately that might be part of the issue.
How old is this PS, I wonder ?
This 40 to 50 years old! No transformer or anything, just a big giant poinometer kind of thing used to change the voltage on both AC and DC from the wall plug of 115
Link in post #2.where is the schematic ?
Eighty four is 40 yrs. ago this yr.I'd be surprised if it's actually 40-50 years old. Ain't no spring chicken for sure, but 40-50 seems like could be a stretch.
I absolutely agree !The capacitor seems to be staying charged and, afaik, advanced age of the capacitor would only make it drop faster, not hold out longer.
Is a point, yes, but being what looks to be one of those big "computer grade" type caps, I'd guess it's not going to be super huge difference. I have some pretty old ones albeit not quite that old, but still have respectable leakage numbers.
Would be nice if the OP reported back on the results of actually applying a load to the DC output.
AfterPossible, but I thought it was said the AC outputs work as expected. The DC runs off that variac just the same, albeit through step down T2, rectified, and filtered.
Probably not a whole lot more to say/discuss without some feedback from Larryhere40.
Could the DC voltage controlling variac malfunctioning with shorted windings, some how and not be able to reduce it`s output all the way down to zero ?
Got back, looking at it, after changing the regulated voltage transistor, I never applied a large test bulb, just use the voltmeter. So after applying a larger draw, it seems to work fine now. Seems like it needed more than just the meter. Thanks for all the help.Possible, but I thought it was said the AC outputs work as expected. The DC runs off that variac just the same, albeit through step down T2, rectified, and filtered.
Ah, more info leaks out with updates on this not common and unique bench variable PS !Got back, looking at it, after changing the regulated voltage transistor, I never applied a large test bulb, just use the voltmeter. So after applying a larger draw, it seems to work fine now. Seems like it needed more than just the meter. Thanks for all the help.
