dr*audio
Fish fingers and custard!
1. The rf; your scope needs to have the sweep set faster, maybe 2uS/div.Greeting
Thank you, Dr, for being a steadfast contributor to the resurrection of many a fine CD player. I've got a new one for you, if you please.
Context
This Sony CDP-C35 is very susceptible to skipping from light taps on the table or from tonal vibrations. TOC loading, seeking, playing are good if not disturbed at all. Track seeking takes about 3 seconds. I've verified the top arm yoke is not contacting. I can wiggle it with the whole CD tray while playing and get no rubbing or skipping. Pickup springs have been re-stretched and suspension feels sturdy yet compliant. Lens looks clean. Spindle motor top bearing lubricated. All transport mechs clean and lubricated. I can hear a lil repeating noise from what I think is the tracking or focus motors, once per revolution of the CD. The motor itself seems quiet when it first spins up or down.
I'm very very new to using an oscilloscope so don't assume I'm measuring things correctly here. I totally understand that teaching OSC operations is outside the scope of this thread.
RF
RF measurement looks messed up. Do I need to set a trigger mode on the OSC to properly see the diamond pattern or is this simply not right? There's nothing in the manual to suggest how to calibrate this.
Focus
I'm pretty sure I have focus set properly to ~100mV center. But, am seeing conflicting info in the svc manual.
In the manual I see this
View attachment 3312576... and thisView attachment 3312578
First graph is centered on 100mV with a 200mV p-p. Second graph is centerd on 0V with a 500mV p-p? What is correct? Why are these different?
Tracking
I don't think tracking is correct. The screenshot in the svc manual is hard to interpret. I think the manual wants to see a 2v p-p amplitude with a 0v center? Best I can get is about 700mV top to bottom.
Again the two sections of the svc contradict each other (unless they mean different things I don't understand yet)
View attachment 3312579View attachment 3312580
My interpretation of the first image shows 0V center with ~2V p-p? Second graph shows 0V center with 100mV p-p?
Thanks
Thank you for your time!
2. The focus is ok, I think.
3. The Tracking offset is adjusted with the tracking gain turned down, then you will see the 2V p-p waveform, and you quickly adjust for 0V offset (waveform symmetrical above and below 0.
The rhythmic ticking you hear is an important symptom. Look at the spinning Cd and see if it is eccentric or if the outer edge moves up and down. Could be the motor shaft is bent or there could be foreign material on the disc table.
