I guess I should have been more specific. I meant like a three way speaker with a woofer, midrange, and a tweeter all in a single cabinet. And not the exotic variety that most people can not afford.
I gave up on powered subwoofers many years ago because the built in amplifiers always eventually fail. I’ve had Polk Audio, Klipsch, and Velodyne servo powered subs and it’s always just a matter of time before the amp goes belly up. I’ve moved on to building passive subs and using a pro amp to power them instead. I always wanted a pair of true full range speakers so I guess I’m just gonna have to build them.If you wanna play you gotta pay.
Easier to just get a pair of 12" subwoofers and use them as speaker stands, 20hz capability easy peasy.
Hey now there’s a Def Tech model I haven’t listened to. Sounds promising. I’m familiar with the BP-2000 and the BP-3000 because I used to install residential systems in the late 90s and the retailer I worked for sold Def Tech. But those have built in powered subwoofers. I don’t recall the BP-30.Also, have a pair of Definitive Tech BP-30 that are rated 18Hz - 30kHz, but no +/- given. Somewhat common opinion is those ends probably are either -6dB or -10dB points. Regardless, they have pretty decent low bass. Four 6.5" (per speaker) in transmission line tuning.
So......one woofer, one mid, one tweeter, single cabinet, not expensive, 20 to 20k hz response + or - 3db, all passive.I guess I should have been more specific. I meant like a three way speaker with a woofer, midrange, and a tweeter all in a single cabinet. And not the exotic variety that most people can not afford.
The CVs he had would do 28Hz.Frequency response: 28Hz-22kHz, ±2dB, -6dB at 23Hz.
Let's see, Infinity Modulus subwoofer, purchased in 1991, driver refoamed twice still rocking hard. $2000 in 1991 dollars, you get what you pay for.I gave up on powered subwoofers many years ago because the built in amplifiers always eventually fail. I’ve had Polk Audio, Klipsch, and Velodyne servo powered subs and it’s always just a matter of time before the amp goes belly up. I’ve moved on to building passive subs and using a pro amp to power them instead. I always wanted a pair of true full range speakers so I guess I’m just gonna have to build them.
Then check out the BP20, auditioned them in 1991, they rattled the store's plate glass windows, no powered subwoofer.
So a sealed cabinet around 10-12 cubic feet of internal volume with dual 4 ohm 15” woofers wired in series that have an Fs below 20Hz that extend up to 1kHz crossed over at 800Hz at 12dB/octave low pass paired with a compression horn crossed over at 800Hz 12dB/octave high pass wouldn’t work? It can be done. Maybe no one makes them because of the WAF. Fortunately that doesn’t exist at my house. And yes I have a wife.So......one woofer, one mid, one tweeter, single cabinet, not expensive, 20 to 20k hz response + or - 3db, all passive.
Really?
Drop the "not expensive" and "one woofer, one mid, one tweeter" criteria and this can be done. Drop the "single cabinet" requirement, this can be done.
Think about it, with one woofer and one mid, the woofer often plays up to 800hz or so. How is a woofer that plays up to 800hz supposed to also play flat to 20hz? Ain't gunna happen.
You might as well start looking for a unicorn.
Pictures of your speakers please.Maybe no one makes them because of the WAF. Fortunately that doesn’t exist at my house. And yes I have a wife.
