And a happy Friday to everyone. I came across an old Western Auto Truetone tube console, that wasn't in the best condition, cosmetically, so decided to see what I could use out of it. The tuner, preamp, and power amp were all on one chassis, so all l could salvage was the transformers and tubes. The amp portion of it was a stereo single ended 7868) (never seen a single ended 7868 before) and the output transformers looked pretty good. 12AX7's and 7868's tested good. So I put together the amp in the pics. I copied the amp and power supply from the original schematic, adjusting the power supply levels to compensate for the tuner and preamp which wasn't being used. The only problem that I have, is that there is too much bass. I can compensate for it by turning the bass way down on the preamp, but would like to correct it. Everything is as shown in the schematic except have a .01 cap, and 470K grid resistor in front of the 12AX7. Any one got any suggestions how I can reduce the base, and possibly boost the high end a little? Bill
