Hello all,
I’m exploring a possible repair on a Pioneer SA-1490 receiver I got from a friend who insists it was working for him before giving to me. I’d like to save it from the recycle pile but it’s not working now.
Two sentences about me. Although trained as a EE, I’ve leaned on more of the theoretical and DSP software side for most of my career. I can (mostly) read a schematic but attaching that to practical and the physical realities gets tricky for me. I have little practical experience.
So, here is the symptom. At turn on, the delay for turn on transient settling flashes a light on the front panel. The input selector light is on the last selected input and after a few seconds the flashing light settles to on. However, the top part above a cosmetic crease in the panel, nothing lights up. This part houses graphic equalizer tone controls (I’m 99% sure they should). Behind that front panel is only one circuit board for both top and bottom parts.
To debug, I started at square one and tried to verify the power connections going to that circuit board. The rest of the description references p.6, coordinates B10 of the schematic, of the online viewable service manual at
https://archive.org/details/manual_SA1490S_SM_PIONEER_EN
The connector CN3 (coordinate B10 of the schematic) goes from the power board to the board behind the front panel. I was able to verify that pin 1 of that connector has power (measured at C503, 5.3V versus the 5.6V it should be, which is probably not fatal). However, a close relative of pin 7 is the output of the rectifier (coordinates C11, right above capacitor C511) where it shows it should be 20V, measures next to nothing. All the fuses are okay so that’s not the problem.
Here’s where I need the practical help. I’m not sure what to do next. Does the fact that the near 5V supply looks good mean that the transformer is probably good and the fault is elsewhere (meaning that the capacitors supporting that rectifier may be at fault)? Or could that part of the transformer (those particular taps) have failed because historically/likelihood that’s what would have happened? If it is the transformer, is replacement unlikely making repair impractical?
I apologize if this is the wrong place for this kind of post but I’m not sure where else to turn. If there are recommendation for a better place (forums), please make them. If there is guidance for this repair here, I certainly welcome them. If I can do my part to lessen the burden on our landfill/recycling and get a receiver out of it, that’s all the better. Thanks in advance.
-Rocky_714
-Rocky_714
