Asterisk3095
Hello AudioKarma!
Recently I have noticed that something in my turntable setup is causing channel imbalance. The left channel is 3-4db louder than the right channel. When listening, it sounds like the center of the music is around my left eye
My setup is basically Grado Green3 cartridge -> Yamaha YP-B2 turntable -> Fluance PA10 phono preamp -> JDS Labs Element II headphone amp/DAC -> headphones (the model varies; I have a few pairs)
I’ve done some troubleshooting and I believe I have tracked the problem down to my Grado Green3 cartridge, or the stylus
I just want some extra confirmation because I’m not really in the mood to spend that much on a new cartridge haha, and would rather spend a bit less on a new stylus
So far to troubleshoot I have:
1. Used a pc to input a mono signal into my headphone amp (sound was balanced so it’s not the amp)
2. Switches the left and right channels on my phono preamp (the channel imbalance switched sides, so it cannot be the preamp)
3. Tested the cartridge on a different turntable (left channel was still louder)
4. Realigned the cartridge, readjusted antiskate (same number as tracking force), readjusted the tracking force (1.75g), and readjusted the stylus overhang (also did not help with the channel imbalance)
As far as I can tell, everything points to either the stylus or the cartridge being the problem.
I would say it’s the cartridge, except that the stylus does appear to be slightly bent (picture attached below)
However, I am unsure if this is off center enough to cause this much channel imbalance
