lattiboy
Well-Known Member
Hi all,
I’m looking to bi-amp (had bi-wire there at first!) my Vandersteen Treo CTs and need some help.
1) I have this tube amp, which I think is very good! I upgraded the 6n2 with some gold lion tubes and was quite happy with the performance. However, one of the stock 6P1 tubes gave out and I want to upgrade all of them. I don’t see hardly any recommendations online for the 6P1 tubes so I’d appreciate any specific recommendations for an upgrade (not looking to spend more than $25 a tube)
2) I also have a great little APPJ EL34 amp that the previous owner (an engineer and designer) went hog wild on and upgraded all the caps and tubes. Sounds absolutely incredible!
3) Because it’s working and the other amp is offline, I tried using the APPJ for the mids and tweets on the Vandys…. and it was incredible!…… at about normal talking volume. Absolutely fell apart above that and I tend to listen loud, so I require more power.
Having used both of these amps extensively, the Analog Acoustics amp is easily 2x louder even though it’s only rated at 2wpc more. So, I’m hoping I can use that and not invest another large sum of money for a 15-20wpc tube amp.
4) If it isn’t enough, what would you all recommended in that power range? I’m fine with vintage, but think the Chinese stuff sounds great and I know I can get it affordably. I had the Yaqin ML10 (?) many years ago and thought it was great, but they’ve gotten quite pricey now and it seems like overkill for this application.
PS I’ll likely be using a Schiit Saga+ as the dual-out preamp if that makes any difference.
PPS Anything I should be worrying about here besides matching levels between the bass and mid/tweet amps? Never bi-wired like this before….
PPPS Yes, I have looked at high-power tube amps, but the Vandys need a simply ludicrous amount of power, and the only amps that drive them correctly are 150wpc or more.
/rant
/rant
