I’m looking for some tube-ish smoothing effect on the highs as my system is extremely transparent and can be a little bright with some material. I use my THX onyx as a preamp / DAC as it just matches perfectly with my Denon POA2200 and allows me to adjust volume with my phone. My understanding is the Yaqin has a small volume drop which can be easily compensated for and it simply passes through the signal when off, which is ideal for me.
Maybe in a few months when I have time I’ll drop the $$$ to get a 50wpc tube amp and see if I prefer it, but I think with the odd Vandersteen configuration I’m going to run into a lot of problems trying to bi-amp like adding a bass speaker i don’t have room for.
Thanks to everybody in the thread for de-mystifying this for me!
Ahhh . . . well this is the first time you've mentioned that you have an issue with the system being overly bright.
Just curious . . . my impression was that you were usually running the speakers with just a tube amp or, at other times, with just a SS amp. Correct?
If so, is the system too bright when powered by the Analogue Acoustics AA-001 tube amp you linked in the first post? Or just when you run the system with a SS amp?
You should be able to solve the brightness issue with your streamer's DSP.
I don't have DSP but, among other functions, they generally have sophisticated EQ capabilities, including a parametric EQ. Semi-Parametric allows you to boost or cut the frequency of your choice. Full parametric adds the ability to boost or cut in an adjustable (narrow or wide) range on either side of the chosen frequency. I believe most DSPs offer full parametric.
Just set it to cut a bit and then adjust the frequency until you find the one that you find troublesome. Then fine tune it from there to determine how much of a cut is needed and then adjust the width. DSPs typically have numerous customizable presets which can be switched in and out as necessary, so you can come up with several of them.
EQ adjustments often solve a lot of problems. Traditional "tone controls" are often shunned these days, yet the use of DSP to make "room corrections" to the frequency response is considered to be quite acceptable. Go figure.
Please let us know how the Yaqin buffer works out, though. It's entirely possible that it will smooth out the highs nicely.
When I said that buffers sometimes don't have much effect on the sound, that was based on comments I'd heard about one of the Schiit preamps. As I recall, it's a SS preamp but it has a tube buffer section that can be switched in and out. Many users report that switching it in has little to no effect on the sound. Hopefully, the Yaqin circuit is more noticeable.
I looked up the Vandersteens and they are relatively inefficient speakers, only 85 dB sensitivity. Were you getting enough volume using only the AA-001?
If you want more power I still think you will get better results, at a
much lower cost, by trying an inexpensive active crossover, or your DSP's if it has one, with your existing amps rather than spending big $$$ unnecessarily on a 50w tube amp.
It's entirely possible that an active crossover could work fine without having to add another set of speakers or a sub. I would at least try running the lows through your SS amp to your speakers lower bi-wire terminals and the highs, through your AA-001 to the higher bi-wire terminals. The key is to set the correct crossover point on the active crossover.
Earlier it was suggested that the higher bi-wire terminals divide the signal at 900 hz. If that's true, set the crossover there. If you ran the mids/highs with your APPJ tube amp previously you can confirm if the division is at 900 Hz, which is quite high, or 80 Hz, which is where the woofer crosses. If it's at 80 Hz, that would be preferable but the higher point would work too. The higher the frequency, the less power is needed so your tube amp will likely have plenty of power in either case.
