Tube amp topologies
I'll really have to crack the books to get this.....
Could someone post what type some of the common tubes are? And/Or what type of circuits they might be used in....
EL34...very common
EL37....more rare...had a Fisher Model 100 monoblock that used this tube.
7591....also see this one in fisher equipment.
6V6.... this one seems pretty common also.
Thanks :music:
I believe all of those outside of the 6v6 are power pentodes. The 6v6 is a beam power tetrode.
Sent from my iPhone using Tapatalk
What baffles me is how you can put an electric current through a certain combination of tubes, capacitors, resistors, transformers, diodes and wire and stuff and stuff and magically it turns into music. I don't understand electricity because I can't see anything move...that's why I'm a mechanical engineer. So much easier....
I am yet another newbie here. I wish I had found your original thread a while ago. Very simple and yet informative. I too encourage you to expand upon this "For Dummies" approach. When you speak of output tubes in parallel. This means literally that the outputs are ganged together before the OPT? This does not cause any feedback or resistance problems for each of the ganged output circuits? What is the practical limit to such an approach?
All things said and done, when the audio signal gets to the end of the amp itusally goes into a transformer. Wouldn't the quality of the transformer has a big role whether the sound went through tubes or transistors. I have a MC252 that I am told has a very tube like sound. If I went to a similar McIntosh amp would the sound change much compared to the maintenance ?
That brings about another question... OTL amplifiers ?
""Output Transformer-Less" (OTL). OTL amps do not use an output transformer, are fairly exotic due to the number and size of tubes requires, and other factors. They are worthy of mentioning, but beyond the scope of a document aimed at a novice."
thank you so much for the write up,this is exactly what sort of information that newbs(like me ) to the tube amp game really appreciate,thanks!
I think the reasons for excluding OTL are slightly overstated here. I have made a couple of OTL amplifiers that use just two output tubes per channel, and they achieve 25W per channel. The tubes are powerful, it is true (Russian 6C33C), but fairly easily available. There is nothing particularly complicated or exotic about the circuits.
Chris
I have a question about transformer speaker outputs on my Audio Research D-90 amplifier.
I just finished repairing my D-90 and it is back to sounding great. I am baffled as to why the output transformers for the speaker terminals are configured with the 4 ohm speaker connection grounded!! Why not the low end of each transformer?
This is done to enable balanced negative feedback to the first stage.
I was looking for a good place to post a link to this video discussing phase inverter theory
I think it's quite good
But if it's in the wrong place or already posted, please let me know
Thanks
WOT
Thanks
WOT
His diagrams leave off some important details, though he does state in explanation some "suggestions" as to why they work. He leaves off the critical resistor from the cathodes of the long tails pair to ground that actually lets the cathode of one drive the cathode of the second. I can forgive that omission. What I do have an issue with is the diagram of the paraphase inverter. His diagram put both the output of the first tube and the input of the second tube at the same level. The one resistor to ground in that image would not "bleed off some of the signal". That design needs 2 resistors to do that. One from the bottom tube ground as he showed and a second from the output of the first tube to the input of the second tube. That could be seen on the Fender schematic he posted as at the point that fed the signal to the 2nd tube was fed by resistors of differing values. Pause the video at about 18:28 and take a look at the point that feeds the 2nd tube. That is connected to the outputs of both phase splitter tubes, the upper tube by a 1 meg resistor and the lower tube by a 25 K resistor. That difference is the resistance I am talking about.
Other then that is is a good explanation.
I'm as green as you can get. I really like the youtuber Uncle Doug he explains the basics in a way anyone can understand. I also think your article is very good for the new learner. Thanks!
After quickly glancing through this topic, is it true that OTL adds the least amount of "tube color" to sound? My SS setup sounds a bit sterile and I'm interested in trying a tube buffer or a pre to see if it helps to bring in some life. Do buffers or preamps even come in non-OTL flavors? There is Darkvoice 336SE OTL available on Massdrop now which gets positive reviews, it can be used as a pre, but if it is indeed very transparent as OTL while it is good overall it may not work very well for what I'm trying to achieve. Thoughts?
the common places for interstage line transformers are balanced audio configurations. Common in pro audio vintage designs. Balanced audio was not common in consumer equipment sectors.
I'm writing this for a few friends, it's meant to be an entry level primer on tube amp topologies...
Start by reading the first few pages of any edition of the RCA Tube Manual... a wealth of information. Then check out the basic audio amplifier schematics at the back. Then graduate to RDH4.
Cheers,
Roger
I'm writing this for a few friends, it's meant to be an entry level primer on tube amp topologies. I'd like to keep things very general, so that a newbie to the hobby can gain some vocabulary for the various tube types and output topologies. There are exceptions to probably everything I will say, but I wanted to share what I could in as general language as possible. There are other threads for hard-core techies, this one is for the novice.
Triodes have one and only one "control grid". Triodes can be used in Single Ended Triode (SET) circuits, and in push-pull circuits. If a true triode is used in any circuit as an output tube, it can not utilize "pentode" or "ultra-linear" mode.
Pentode tubes have three control grids, and the addition of the extra grids allows the pentode to be run in various different output modes: triode, pentode, and ultra-linear. Triode mode mimics a true triode tube, is often of a lower power than the others, but is popular because of it's sonics. Pentode mode usually uses a tube to more of it's maximum output potential, and often gets the highest power ratings out of a tube. It's generally fallen out of favor, but making a comeback in certain DIY circles. Ultra-linear mode is sort of a compromise between the two, with power ratings between triode and pentode. Ultra-linear mode is only possible if the output transformer has a special tap that supports this use.
There are three basic output topologies for tube amps: Single Ended (SE), Push-Pull (PP), and "Output Transformer-Less" (OTL). OTL amps do not use an output transformer, are fairly exotic due to the number and size of tubes requires, and other factors. They are worthy of mentioning, but beyond the scope of a document aimed at a novice. As both SE and PP amps require an output transformer (OPT), the characteristics of that transformer will dictate many factors about the amp. Generally speaking, an output transformer will be either a single ended OPT, or a push-pull OPT. Either PP or SE OPTs can have an ultra-liner (UL) tap. If your output has it, you can optionally use it. One could argue that the output transformer is the most critical part in a tube amplifier.
A Single Ended amp uses a single output tube. If the tube is a native triode (300B, 2A3, etc.) this is a SET amp. You can run a pentode in Single Ended Pentode (SEP) mode as well, but it's not a SET amp. Using a pentode, you can have a Single Ended Pentode (SEP), and if your transformer supports it a Single Ended Ultra-Linear (SEUL) mode as well. It is possible to switch between these modes.
Push Pull uses a pair of tubes to power the speaker. Triode, Pentode, and UL modes are all available here, too, depending on the choice of tube and transformer.
Parallelism is also possible, usually for more power. A Parallel Single Ended (PSE) amp will use more than one tube run in single ended mode. A Parallel Push Pull (PPP) amp will use two or more pairs of outputs. While it's usually easy to spot a Parallel Push Pull amp because of the number of output tubes (4, 6, 8, etc.), the most common Parallel Single Ended amps can resemble a Push-pull amp, as each have 2 output tubes. Generally speaking, parallel amps are not as common as non-parallel. Vintage parallel push pull amps were often PA type amps. Parallel Single Ended amps seem to be more common in modern times, as people want more power while trying to retain some single ended sonic characteristics.
Single ended amps are generally prised for their sonics, but put out less power than push-pull amps. They are generally simpler and have less parts than a push-pull amp. They tend to be fussier about hum and noise, so particular attention must be paid to the quality of the power supply, amplifier layout, careful heater wiring, and other factors that induce noise. In some ways, parts selection becomes more critical because there are fewer of them to begin with. This can work to a DIYers economic advantage too, as sometimes it's possible to use a budget for fewer but higher quality parts. While circuit choice is still very important, due to the simplicity of the design, most SE circuits resemble each other to a great degree.
Push-pull amps generally have more power than SE amps for any given tube. Generally speaking, they tend to be more complex then SE amps, with a higher parts count and more tubes. They have some noise-rejection qualities inherent in their topology, and sometimes this can present less of a problem to get noise free. Choice of circuit can be of particular importance in a push-pull amp, some can really sound better than others. There is also a greater number of circuits to choose from, as different designs handle the more complicated push-pull circuitry in different ways. Parts selection is still important, but perhaps circuit choice is even more critical in a push pull amp.
Thanks for all that info! I have a question... What type of tube amp would power a turntable w/o a preamp? I am looking to try to switch from a solid state receiver to tube power. Would I need a preamp in addition to the vacuum tube amp? Also, are these new 'combo' SS) tube hybrids useful for anything other than Digital DVD players, ipods, etc? Thanks a lot!
