Lavane
Lunatic Member
That too.I thought it was Bankruptcy On A Trailer.![]()
I run a Variac for my Fairchild 260's, and bring the voltage up to 115 V slowly. even though the 5V4g rectifier's come up slowly, i was told a lot of theTube life-use /abuse comes from initial turn on . When long sessions are expected I also use a small fan to keep them cool
Thanks guys!Looks like your board has Sprague Orange Drops and Mallory brown drops. If the rest of the unit has these coupling caps, you'll be good to go for a long time. I would not put in any boutique coupling caps, if you want long reliable life from your tubes. I presume those capacitor cans are relatively fresh? Less than 20 years old? Bias supply caps under 20 years old?
Check bias once every six months. Get a used Dynaco wired lid on the top. So you can't inspect the amp every second it is turned-on. Hide the amp a bit, in an area with plenty of air space above and below it. Do NOT turn it on-&-off several times a day. Blackburn Mullard EL34 are good tubes. Should last a long time. Save money and get another set. BTW... Matsushita GZ34 is built from same machinery die as the famous Blackburn Mullard GZ34. And we all know how long those last.
https://www.dynakitparts.com/shop/dynakit-st-70-cover/
Thanks guys!
I installed a new capacitor 30,20,20,20uf only several days ago. (Which I did have bypassed internally beforehand)
Original bias caps where 50uf,75v. I replaced with 100uf,200v.
I bypassed the Selenium diode with Silicon 1N4007.
Installed mutch nicer Gold RCA jacks by modifying the original RCA mount to use the ones I had.
I also removed and snipped almost every solder joint. And replaced all the older solder on the PCB with silver solder I had left from my Magnepan repair kit.
Replaced the bias resistors that either had an iffy tolerance, or drifted.
And also replaced both bias Pots with the far nicer/smoother, and more accurate ones from Dynakit.
Also running the amp on 115VAc.
