Tube Matching
jcmusic
Well-Known Member
What is the best route to take when matching small signal tubes? Matching the two sections or different tubes?
Jay
Jay
If it's a stereo unit, both. (e.g. 12AX7's)
I match the sections in tube 1 first, then tube two.
Next, I match between tubes.
If I'm lucky enough to find exact matching, one gets the left channel, and one gets the right. If not, I'll look for a fairly close-matched tube, and another fairly close-matched tube. . .only mirrored.
In other words, if tube 1 measures 1125/1250, and tube 2 measures 1250/1125; I'll put tube 1 in the left channel and tube 2 in the right channel.
I did this by accident in one of my mastering studio preamps many years ago and found there was a slight difference (widening and imagery) of the stereo field.
. . Falcon
Best way to truly do it,
Is install them into a piece of gear where you have measured both the cathode resistors
an plate resistors for both sides of the triode and they are extremely even, then you do
a voltage test with a meter at the plates of both triodes, then try various tubes till your
confident you have the best matching voltages you can get. Measure cathode voltage to.
That is the best way to do it, under "real" conditions, as the tube tester just can not do it.
