@MCM_Fan is correct, if you get us some pix we can give you info on a new tip.
I say start there, you are in the right place on AK, tables are not complex to work on, delicate but not rocket science... if you have any experience with hand tools at all, you should be fine.
https://www.lpgear.com/product/CF95SE.html
If you decided you don't want to use the cart that is on it, you should check out the LP Gear CF95SE, its an AT95 body with a carbon fiber stylus. Low buck, yet has great sound. It won a few awards for the best cart under $100 bucks. They are under 60 now... Fantastic cart, was a game changer for me. I ran the Shure M91Ed and this low end cart blew it out the water. I just picked up a new Blue Point No.2 yesterday, I will be comparing it against the CF95SE this weekend. Dollar to sound ration should say the MC cart will blow it out the water.
This is the CF95SE ^^
PB No. 2
I say start by getting a new stylus for your cart, lube your motor and arm.
you should be able to find the Service manual for your table at Vinyl Engine for free, the manual will show you where to apply oil.
You will want to use a 100% synthetic bearing Oil.
Focus on the little things and dialing in the arm prior to throwing money into a cart. tables are a lot of fun, and when set up properly they can be really rewarding.
Congrats on the table! Would love to know your thoughts on it when you get to listen to it.
