I haven’t seen anyone mention record cleaning in reference to clamps/weights, nor vertical clearance. So I’ll dive in on those subjects.
Vertical clearance:
I play records with the dust cover CLOSED. It’s quieter and I pick up *far less* dust during record play. Most clamps are tall, not allowing play with my dust cover down. So I use a low vertical profile record *weight.*
Cleaning Surface Dust Prior To Needle Drop:
Most in here remove surface dust from the record surface prior to needle drop, no? I know I do.
With dish-warped records, there is very little contact between the platter mat and either the record outside edge, or label, depending on side being played. Even ripple warps drastically decrease record contact. When using a lint brush prior to needle drop, I’ve had the problem of the record spinning on the platter mat from friction between brush and record surface. To prevent this, I use a record weight; I never have the problem of the record spinning against the mat when brushing the lint off the record surface before playing.
Bearing Wear/Rumble:
I haven’t seen this as a problem. My current table has a 5-lb platter. It uses a Delrin dimpled block and a ball bearing thrust support at the base of the spindle. When I took it apart to clean it, and add synthetic oil (2 drops) to the thrust bearing, and radial bearings, I first made very fine scratches in the Delrin block. Using a razor blade, I made 8 radial lines from the center of the dimple, out to the edges. This allows circulation of the oil under the ball as it turns in that dimple. That was 4 years ago. 2 weeks ago I checked it, to see how my circulation system was holding up. I found my scoring lines still there. Oil circulating nicely! No wear at all. And it’s dead quiet. I hear no rumble, even using a stethoscope borrowed from a blood pressure kit.
