SeattleMan- I did some measurements on my PS-10's and for ideal fit-up you will need a tweeter that is 3-3/4" outer diameter with 1" dome. You may want to verify the cutout size (hole diameter) on your tweeter location as well, as that will be important too. Toxcrusadr detailed the need for tweeter to work down to the 2000 Hz range in post #20. For reference here are some photos of a damaged PS-10 tweeter that shows disassembly to locate the bad/open spot in the voice coil and the person was able to affect a repair. It wouldn't be easy, but the photos show that the tweeter can be disassembled if you wish to give it a try. These photos are all "borrowed" from the Design Acoustics Group on Yahoo. The tweeter you have linked to is not an ideal mechanical match along with the different roll-off frequency (higher than desired- 3500 hz vs. 2000hz). Since the outer diameter appears to be a bit smaller with the Simply Speakers replacement you are looking at, you would have to drill at least two new holes to accommodate the different mounting screw hole locations. If you are forced to go that route I might suggest you actually rotate the driver 60 deg CW or CCW from the stock hole location/positions so as to avoid weakened area of the baffle board due to the existing holes. And drill three new holes. Again, not an ideal replacement and quite a bit of work for a driver that isn't a good frequency response match on the lower end of its range. Hope some of this info helps.
